Results 1 to 10 of 10
Thread: Alarm goes off for no reason - any ideas as to fix ?
    XUV
    XUV is offline
    HSV XUV
    Feb 2009
    Default Alarm goes off for no reason - any ideas as to fix ?
    As thread says the alarm on my VY11 HSV XUV goes for no reason .
    any one got a fix or a why ?
    I've been manually locking it , so as not to activate the alarm ,
    but force of habit , I click the key button and then a few hours later it goes off .
    Is there a sensor I can replace ?
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Shock sensor!! or could be a loose wire somewhere.
    Did u install urself or did u get someone to do it?
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    my VK used to be bad for going off when harleys or cars with deep exhaust notes went past used to be a little annoying.you may need to adjust the shock sensor if it has an adjustable one.
    VT Berlina S1
    Sep 2007
    Am i wrong in assuming that the VY reports the location of the alarm trigger on the dash LCD?
    I know the VZ does it. Reporting things like Boot or Drivers door.
    Wouldnt it be easier to just walk out, unlock the car, put the key in the ignition and start it, then read the reason?
    XUV
    XUV is offline
    HSV XUV
    Feb 2009
    yes , passenger doors , is alarm report ,
    whuich I gather is rear doors on a crewie .
    HSV/Holden fitted alarm .
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    not 100% sure with factory, but have you changed the interior light bulb to something different? or have one at all? preety sure they would be part of the trigger system in the door (share same switch, same circuit)
    XUV
    XUV is offline
    HSV XUV
    Feb 2009
    Can the alarm be turned off thru workshop diagnostics ?
    as i think maybe the locks might be sticking .
    04' VY SerII Acclaim
    Apr 2009
    has it always been doing this dude?..coz with my vy you have to use either the key to unlock and lock or the remote to unlock and lock...otherwise the alarm goes off.. i wasnt sure if it was meant to do this either but never really bothered to find out.
    YMY-88U's Avatar
    YMY-88U is offline Donating Member
    Project VH SL/E
    Jun 2005
    hey guys ,
    remove your clock spring/horn pad on vy and vz's the factory sticker they put on the steering wheel is made from aluminum and after few years starts peeling and conects the circuit for the horn...that is if it just the horn randowly going of for no reason, it happended in my old vy ss
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Quote Originally Posted by scorp View Post
    Thanks for that.... using the key still sets of the alarm! :@ Trying to leave a friends house last night at 5AM, trying to be quiet, i figure pressing the button will set off the two horn beeps to unlock it, so i'd use the key, that was good, it unlocked, but as soon as i opened the door the alarm went off! Everyone in her street probably heard it.
    Lesson learned, always use the buttons on the key!
  1. VN diff in VK - it should fit - any reason why not?
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-06-2010, 12:04 AM
  2. I need a reason
    By BlackVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-09-2008, 03:46 PM
  3. Car alarm install ideas.
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-09-2006, 11:14 PM
  4. Car Alarm goes off for no reason
    By Harry V in forum Electrical Wiring / Questions
    Last Post: 06-07-2005, 10:03 AM
  5. (VT) the horn was going for no reason
    By rubyredboots in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-07-2005, 05:51 PM
