i have a 5 speed vy spack series 2 and wanting to no which is quicker the vy or the vz sv6 manual?
my gfs friend has one and she wants to dragand there both got exhausts
sv6 manual will eat it
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
ok then no worries
Depends what speed you are dragging to. Ecotec will be better off the line, then the Alloytec will take off.
There wont be stuff all difference between them to the legal limit try it and see for yourself, at a track of course
the sv6 all the way more mid range power of the line
VZ will win... and here are the numbers to prove it...
VY
Power: 152kW @ 5200rpm
Torque: 305Nm @ 3600rpm
VZ
Power: 190kW @ 6500rpm
Torque: 340Nm @ 3200rpm
Now you also need to consider the fact the VZ sv6 is actually 43kg heavier that the VY, so you have an extra .5 of a mate with you...
Finally... although we all know factory 0-100kmph numbers normally mean bugger all...
The VY will apparently do it in 8.5 seconds while the VZ will do it in about 8.3 (I think).
That's stock for stock anyway...
So yes... a VZ will be quicker off the line and get upto speed quicker... but not by very much
It has more torque sooner and more power up top...
both manuals, vz gets a bad start, you get a good launch, your in with a chance.
but on paper, VZ will eat you.
Not worth the risk of losing to your gf's friend. She'll never let you forget it.
A Commodore is a passion. Anything else is just a car
yeah i no i might put extractors on and then maybe give it ago, but anyways draged my mates xr6 semi auto ba ute earlier and left it for dad
The Blue One
dont also look at the engine specs, look at the gearbox ratios, the aisin box has a first gear of 4.5:1 even with the 2.87:1 this makes for a pretty good launch, not sure what the getrag 1st is like, but it has a 3.08 diff,
lsd or single spinner will make a differance too
if a 3.46 diff was fitted to the sv6 and that first gear you could launch into space with it
yeah theres a bloke down the road from me with one so might see which is quicker wat r ur thoughts
Depends where you're planning on "seeing which is quicker"
On public roads = don't be a tool
On a private road/track = go for it...
dont have a track where i am mate
well if you want to keep your car, i suggest you find a track.
just heard the cops r opening up the drag strip soon for a race ya mates night so will test it there.
and on another note will extractors off a vs fit on to a vy???
i doubt it. i don't think vs style ones would have the provision for the egr valve
Getrag 260 1st gear is 3.8 or 3.9 off the top of my head.
EDIT: Yay for Wikipedia
http://en.wikipedia.org/wiki/Getrag_260_transmission
DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
Originally Posted by Reaper
