HI all ,new to the forum < I was wondering if anyone new how hard or easy it is to convert the knob style heater controls to the electronic style, is the wiring the same etc . Any help appreciated.
PUTZ
The way I see it would be you are trying to convert it to Climate control, as that is electronic so to speak.
Extractors, 100cpi ballistic cats, Sureflo 3.5" medium exhaust, DUS OTR, Oztrack Tune, Phreddy dash, stereo, black windows, Lovell springs, and a good alarm
Putz, Welcome to Just Commodores.
OK, the question has been asked, and you can always use the search feature to look before you post.
But in answer to your question how easy it is? It's not easy enough to be worth doing.
The wiring and plumbing is similiar in terms of power and ground... that is where it ends. The dial controls are mechanical with cables and air hoses. the climate control variety is just that electroically controlled. And while it is not impossible to do, it will be a headache to attempt.
you'll need to take the bottom console off around the gear lever. remove the radio, source a climate control fascia, source a climate controller Mid to high level BCM, getting your keys reprogrammed to that BCM, engine coolant (climate control dependent sensors) cabin temp sensors. $200-500 depending on where you get it from. then you'll spend most of the day wiring it and working out how to make it work.
Climate control to VY Acclaim
Check out my build <---Click me
Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
Now you put it like that it does sound like to much trouble to go and would cause to many headaches, will leave .
Thanks for the help.
PUTZ![]()
