Results 1 to 11 of 11
Thread: cracked sump
    VY commodore acclaim
    Dec 2008
    Default cracked sump
    hey guys,
    im driving a vy acclaim thats sitting pretty low, i cracked the sump the other day from being silly. and was speaking to a mate the other day whos a mechanic. he said that to replace the sump he'd have to pull the whole engine out and do it that way. hes doing for real cheap cash. but will still cost about 500-600 + ill be getting other stuff done. But i was thinking about it.... does anyone know if i could seal up the small crack ( 40mm long very thin ) with some type of high heat resistant sealer? this would save the time and hastle of taking the engine out etc and a new sump..
    VL EXEC
    Aug 2008
    perth wa
    maybe u could weld a piece of metal over it?
    I've driven fast cars I've done stupid shit in them each time i seem to come out on top i love you guardian angel
    vp ss 3 months to go
    VY ute
    Jun 2009
    There's some epoxy type putty that loctite have that is oil resistant and should seal just a crack up nicely
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I read on here recently that the sump could be removed while the engine is still in?
    VY ute
    Jun 2009
    You need to raise the engine up and support it as a minimum to get the sump out over the cross member and access to bolts. Im about to have a go at doing mine next week if i can find another sump (yet to find a wreckers with one) if not ill patch it for now whilst i wait or may just get it welded up.
    08 VE SS-V 6.0Lt V8 SEDAN
    Mar 2006
    Depending on where the crack is, you could get someone that knows how to weld, and get them to use a Mig Welder, using aluminium weld wire to weld the crack.
    They may have to give the surface a light grind so that the weld holds better.
    Would be better and stronger than metal putty sealant.
    VY SII HBD Calais L67
    Dec 2006
    If you raise the engine and drop the subframe a little the sump can be removed without seperating the trans from the engine. Not a fun job but it can be done and is still less work than an engine pull.
    VYII Calais L67
    pl0x is offline Pl0x
    VT Wagon V6
    Jul 2009
    NZ
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    epoxy putty
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Dont compromise , it will be too hard to weld as the metal has oil soaking which will cause a weak weld , probably leak again down the track- same with any sealants or putty's , to hard to get a good bond. Just try & get one from wreckers or ebay & raise engine / drop front subframe & swap the sumps over , make sure you buy a NEW sump gasket , about $40 from dealer , new sumps are about $180 trade price, $250 retail. Depending on your comprehensive insurance you can claim it on your insurance if yiou have no excess????
    sdewys is offline Banned
    vy 5 speed
    Aug 2009
    have you fixed it yet as i just cracked mine and was wondering how you fixed yours?
  1. cracked sump
    By 94calais in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-06-2009, 01:29 PM
  2. VR A/C Condenser Nut Cracked
    By Bilbs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 12:56 AM
  3. cracked plugs
    By 93 White Shark in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2006, 10:03 PM
  4. cracked oil sump
    By commo69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2006, 10:48 AM
  5. cracked sump
    By cizocizo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2005, 12:26 AM
