Results 1 to 13 of 13
Thread: Car losing power...
    VY SS+Turbo
    Jan 2009
    Thumbs down Car losing power...
    Hiya Guys,
    Hoping somone might have had the same problem..
    If i feed on the power in 1st or 2nd it feels like it periodicaly losses power sometimes it does it if i just plant it..
    Any ideas would be great!
    Luke
    P.S i have a vy ss list of mods are in the my ride section (If the mods have approved it)
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    It can be many things.. Failing/failed fuel filter (released contaminants ending in blockage) . Failing fuel pump, not supplying high enough PSI to the rail. If MAF installed they to can fail and give incorrect readings.. You yourself have to start doing some testing. If you don't have all the required testing tools it may be time to visit a service technician.
    note. without a link to your car's details, not many people will bother looking for it
    It's easy to do - example's shown here
    Cheers,
    Dave
    VY SS+Turbo
    Jan 2009
    Thanks for the reply,
    I changed fuels and it now works fine. i was using E98 (Ethanol 98 octane) changed to shell v power.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    If it comes back, try turning traction control off.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Baldric is offline The BOSS
    VE GTS M6
    Dec 2003
    its just a bad batch of fuel. and your pcm has dected lesser grade fuel and has dropped the spark down to low octane table (less timing) and when you switched to a better fuel quality. it goes back to high octane
    maybe check your fuel filter as well
    ___________________________________
    Car: 07 VE SSV 6LTR L98 A6
    Metalic Silver
    Junny's Avatar
    Junny is offline purrrrrr
    VUII Maloo + shitty painted vp
    Hangman Champion!
    Jan 2009
    Quote Originally Posted by Fresh SS View Post
    isnt ethanol bad for ur car? vpower FTW
    Hit the star under this post if it was any help to you =D
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Ethanol tends to do bad things to the engine. If you can run Mobil 8000 through your car a bit [usually 3 tanks gets all the crap out]. Mobil 8000 is tried and tested as the best fuel on the market and has plenty of cleaning agents in it! I used to run vPower, swapped to Mobil 8000 and my acceleration increased. Now it's the only fuel i put in my vehicle!
    VY SS+Turbo
    Jan 2009
    I run a servo (Freedom Fuels) And they swear black and blue that Enthanol is good for your car, even the handbook says you can run it.
    As for mobil 8000 never heard of it?
    Probley not here in Traralgon
    VE GTS M6
    Dec 2003
    mobil 8000 is the higher grade 98 ron as far as i know
    Metalic Silver
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Quote Originally Posted by alien View Post
    You do know Mobil 8000 is just BP ultimate right?
    Since shell have altered the vpower blend, I have gone back to it, was finding too many inconsistent batches of Ultimate/8000.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    VY SS+Turbo
    Jan 2009
    Ill stick to v-power for now then. I even get better milage out of it too
    Nov 2008
    Tullamarine, Vic
    minux, they are actually two different fuels. There was a test done with all fuels available in Australia from all major servos. This whole test was checked over by a cinematographer with a worked 67 Ford XR who tested all the top fuels suggested. Mobil 8000 came out on top over all the fuels. BP Ultimate was near the top, but wasn't the top. Shell V Power came in second. The test took into consideration mileage as well as power. But, i must mention the test was designed for higher output vehicles. E.g. forced induction 6 cylinders or more. I found i get more mileage from the 8000 than V Power!
    minux's Avatar
    Feb 2005
    You really want to argue with me on this? Mobil 8000 is BP Ultimate with a few extra additives. Essentially the EXACT fuel.
  1. vr losing power sub?
    By love the general in forum Electrical Wiring / Questions
    Last Post: 30-08-2008, 12:24 PM
  2. Losing power around corners
    By Woules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-02-2008, 12:06 AM
  3. my V6 is losing power.Help !!
    By custom vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2007, 11:01 AM
  4. Losing Power
    By AdamAnt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2007, 12:58 PM
  5. Losing Power
    By My Car Pwns in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-12-2005, 11:33 AM
