Hi guys i am after some pics and info I am looking at buying a set of pedders 6412 fornt,6419 rear 2'' all round for my car and just want to see if it will sit to low as i need to drive this car with people in it and dont want it to scrape and also if I will need a camber kit I currently have 18's on it
Im not 100% on peddars, I'd go king springs.
Here is a link to my car, My 03 VY s2
That has SSL's at the rear and SL's at the front, Plus, When i add rims, Its going to look a little more lower because the wheel gets bigger.
2" should be heaps and shouldn't scrape, depending on the kind of roads you have in your area. I'm not to sure about pedders either but I have heard that they are quite good. You might want to either lower the rear a bit lower or not lower the front quite as much to make the car sit level rather than it's arse sticking up.
A Commodore is a passion. Anything else is just a car
thanxs duk13y these are the ones i am looking at buying http://forums.justcommodores.com.au/...s-springs.html but the car is not IRS does that matter also in the pics the car looks level
