Results 1 to 5 of 5
Thread: Difficulty starting, sometimes doesn't start
    Jan 2008
    Default Difficulty starting, sometimes doesn't start
    Hi,
    Engine VY V6 Ecotec
    My car has just started to become gradually more difficult to start. Sometimes it doesn't start and I've had to get a jump.
    I checked the battery voltage and it's at 12v. When trying to start you can hear a clicking noise that remains until you turn the key back to the off position.
    I'm thinking starter/coil seeing that the battery has the correct voltage.
    Any ideas
    Also I've noticed that when I turn a corner and accelerate through there seems to be a slight 'doughyness', almost like a miss or something.
    Any ideas
    Thanks heaps
    Melon
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    is that the standing voltage of the battery? how long after the engine being turned off was the battery checked,
    what was the battery voltage when you cranked the motor?
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Jan 2008
    Standing voltage was 12 point something. The engine had been off for about an hour.
    I must also add that when I crank the ignition the dash lights come on as well.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    might be your started motor drawing too many amps from the battery.... if you battery is low on cranking amps but still has over 12 volts, it should be replaced and the starter motor current draw should be checked
    VY II SS
    Sep 2008
    Sounds like the same problem I have had with past cars.
    The starter motor has little brushes inside and when old, start to get a build up of carbon on the brushes and therefore don't make a clean contact, and don't start the car.
    Next time if your car won't start, get the handle end of a hammer, and tap the starter motor gently to knock the carbon off the brushes. If your starter motor is the problem, generally that will fix it. So for a few months I would just drive around with a hammer in my car hahah.
    Next time your near an auto sparky ask them to have a look at the starter motor. Sometimes it just can't get enough current and only a relay needs to be put in.
    Extractors, 100cpi ballistic cats, Sureflo 3.5" medium exhaust, DUS OTR, Oztrack Tune, Phreddy dash, stereo, black windows, Lovell springs, and a good alarm
  1. car not starting
    By SAV_117 in forum General
    Last Post: 20-11-2008, 08:20 PM
  2. VN Not starting - HELP
    By ghosty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 01:27 PM
  3. vt ss not starting
    By djlingard in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-01-2007, 05:06 PM
  4. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
