Results 1 to 3 of 3
Thread: Joint Number
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Default Joint Number
    OK, because i dont have time to throw my vehicle on a hoist and check or look over the holden manual i'm wondering if anyone knows the answer to how many joints there are between the engine cranskhaft all the way to the wheels. (In a single line and in total). Both CV and Universal.
    Basic idea is to replace all the joints except the rear ones with strong ones before work commences to push more power out of the engine. That way if the joints that are likely to be destroyed are then cheap ones to fix at the rear.
    Still tossing up whether to actually push more power out of my engine or go with another idea i had and change between engine and wheels to get more power [no questions as yet, still a work in progress but will be really unique]. This will probably involve re-inventing the whole drive shaft though. Will make the vehicle different to drive too, might swap to a manual when doing this as well. So depends how adventerous i feel in about a years time i guess.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Nov 2008
    Tullamarine, Vic
    Thanks calaber, that's what i thought, someone said that there was a period when holden was trying 7 in total.
    So plan is definatly upgrade the universal joint cloest to the motor and the centre joint. Then not making the rear universal joint as strong as the front and then leaving the rear 2 CV joints not as strong as the front ones. Meaning they're easier to fix and cheaper to fix too!
    Thanks again,
    alien
  1. ball joint?
    By TWOJZ in forum General
    Last Post: 25-06-2008, 09:11 PM
  2. CV Joint
    By caldonia in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-11-2007, 02:50 PM
  3. CV joint problems
    By GeorgeB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2005, 06:05 PM
  4. Uni Joint
    By midnight.outlaw in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2004, 04:19 PM
