Ok, need some advice/help.
1st
When i turn right something sounds as if its rubbing but not when i turn left, if its the power steering pump would it do it for both ways or just turning right also?
2nd
Might be tied in with the 1st problem, I tried to fit 19" VX GTS to the ute a few months back and they wouldnt fit and they would rub under the front left shockies surround, i took it to a tyre place and he said the suspension might be bent. He eventually got it to fit by putting a skinnier 19 on and adjusting the camber of the rotor slightly. Would this be contributing to the first problem?
3rd
There is a loud squeak coming from the right rear tyre which i was told was my brakes needed skimming, which i had done but now the probelm has come back.
