Page 12 of 20 FirstFirst ... 28910111213141516 ... LastLast
Results 276 to 300 of 493
Like Tree17Likes
Thread: Nic's VYS S1 Manual now Rear Bagged
  1. #276
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by VR028 View Post
    hey mate could u please post up the dimensions of your sub box?
    here is the design, i had to modify the port to fit sub so i added the new port to the design > 6.9cf tuned @ 32hz before displacement
    Attached Thumbnails Attached Thumbnails Nic's VYS S1 Manual now Rear Bagged-6.8cf-32hz-1.jpg   Nic's VYS S1 Manual now Rear Bagged-6.8cf-32hz-2-new-port-.jpg   Nic's VYS S1 Manual now Rear Bagged-6.8cf-32hz-3.jpg
  2. #277
    VR Berlina
    Jun 2010
    VIC
  3. #278
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
  4. #279
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    a little problem with the wiring harness they gave me, wished it was all plug and play but on there ISO the Amp Rem is the illumination , so when i put the acc on, the head lights turned on, steering wheel controls work & are awsome i just gotta mod this wiring harness then it will be all good , one other thing, there was no tel mute wire on it, hmm i wonder why i guess i don't need that connected
  5. #280
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    it was just the Amp Rem was into the Illumination & there was no Tel Mute & no Park Brake wire on it so its all fixed now, head unit is in, gauges are out (there stuffed) and yepp i do my soldering on the floor in my room :P
    and my second bulk pack of Solavis SuperShield, it was around $120-$140 for a door kit of dynamat so i was like fk it and got a bulk pack of Solavis & its just as good as dynamat, so now i can do all 4 doors when i make new pods, and il ahve some left to put elsewhere, any ideas on where i should put it? the boot is already 90% covered in it lols
    sound comp on the 25th can't wait to see my results
  6. #281
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
  7. #282
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    speaker pods went alright but.. the door trim don't fit back on.. the midwoofers are to deep -.-
    so i deadened the doors instead.
    and no i didnt seal it with the mdf or w.e you use, im not a SQ freak! and i didnt feel the need for it. and i couldnt be bothered lols, it does sound much better than before thou, i have a couple sheets left, just thinking on where to put them, should i finish the boot off? theres pictures of what i have done in the boot on page 5
    thanks
    Attached Thumbnails Attached Thumbnails Nic's VYS S1 Manual now Rear Bagged-img_0179.jpg   Nic's VYS S1 Manual now Rear Bagged-img_0194.jpg   Nic's VYS S1 Manual now Rear Bagged-img_0188.jpg   Nic's VYS S1 Manual now Rear Bagged-img_0199.jpg   Nic's VYS S1 Manual now Rear Bagged-img_0207.jpg
  8. #283
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Should have done the MDF mate!! Takes no time at all, costs next to nothing and makes the largest difference in midbass.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
  9. #284
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by sweefu View Post
    yeah i didnt know what to do either, and idk where to find the mdf because where i got my 16mm thats all they had.. and umm, i could always do it later if im that desperate :P, just rip the sheet off that i got covering the hole and i got a couple spare sheets anyway
    i don't think it matters, i got next to no midbass at all with these coaxials lols,
    and im connecting mono amp to head unit 2morro, desperate for my bass when i go back to Tafe on thurs
  10. #285
    Dec 2008
    Don't you have a Bunnings close by? Or a timber yard? Both will have.
  11. #286
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    i got my 16mm from Bunnings and all they had was 16mm in different sizes last time i went because i asked them if they had other mdf with different thickness
  12. #287
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    heres some pictures of what i done today,
    [*] such a mess hehe.. finally wired rca from mono amp to head unit and re did the amp remotes because when JB Hi Fi installed them that time they connected the amp remote wire to the Antenna Trigg which i thought was pretty stupid and now its connected to the "Amp Rem" on the back of the head unit.
    [*] fitted the VY SS Head Lights (and btw.. with the indicators... it was a strait swap. ppl said i would need to buy new globes because apparently they are clear with orange lens.. well they were orange globes and all good
    [*] changed fog lights globes to DiamondVision, same as head lights now (just for looks)
    [*] fixed up the fog light wiring.. before it was just hanging under the car shared ground etc, now its wired up behind head light and throught the back of the engine bay around to the battery and to the relay and connected to the other fog light neg and strait to the battery terminal
    Attached Thumbnails Attached Thumbnails Nic's VYS S1 Manual now Rear Bagged-img_0225.jpg   Nic's VYS S1 Manual now Rear Bagged-img_0249.jpg   Nic's VYS S1 Manual now Rear Bagged-img_0247.jpg   Nic's VYS S1 Manual now Rear Bagged-img_0265.jpg   Nic's VYS S1 Manual now Rear Bagged-img_0264.jpg   Nic's VYS S1 Manual now Rear Bagged-img_0262.jpg   Nic's VYS S1 Manual now Rear Bagged-img_0259.jpg
    Nic's VYS S1 Manual now Rear Bagged-img_0258.jpg   Nic's VYS S1 Manual now Rear Bagged-img_0245.jpg   Nic's VYS S1 Manual now Rear Bagged-img_0272.jpg
  13. #288
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
  14. #289
    Jun 2011
    Man thats allot of bass, Im gonna record mine see how well I goo. I like abit of bass, but more loud music tbh. How many amps you running? Ive got 5 in atm and the two 15's. Ill record mine now.
  15. #290
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by a,vy! View Post
    umm 2, with 4 coaxial speakers lols, i need a door pod like urs but for single 6.5" speaker, really want to get these re splits fitted
    i saw the video.. cool bananas
  16. #291
    Jun 2011
    Was gonna turn the sub right up, it was on the lowest setting through the head unit.
  17. #292
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    should of :P
    speakers are clear as
  18. #293
    Jun 2011
    I hate that bass though, I got it tuned so it kicks more then doff doff, if you no what I mean.
  19. #294
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    I'm going to say this once...
    I don't care how loud your subwoofer is, If the rattles make it sound like shit...
    Mat
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
  20. #295
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by HoZy View Post
    Mat
    im not into SQ as much as you, sorry
  21. #296
    Dec 2008
    It has nothing to do with SQ, your car just rattles very badly, I've seen much louder cars with zero rattles.
  22. #297
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    ohh ok i havnt, and idk how to stop them
  23. #298
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Quote Originally Posted by Nic92 View Post
    learn, its really not that hard. expandafoam + sikaflex + sound deadener + a weekend of funtimes. makes the car so much more enjoyable to be in
  24. #299
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by hakhawk View Post
    wtf is expandafoam.. and where do you put it ?
  25. #300
    Dec 2008
    Most places. Put it between metal panels rubbing together/vibrating against each other.
LinkBacks (?)
  1. Grennan's Black Manual VX SS - Bagged on Red and Black 20's!!
    By Grennan in forum VT - VX - VU - WH - V2
    Last Post: 28-04-2012, 09:57 PM
  2. Bagged vk
    By VKCOMMO in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-01-2012, 02:04 PM
  3. My Bagged VS S-PAC S2
    By Drp_tht_sht in forum VR - VS
    Last Post: 04-11-2011, 08:12 PM
  4. VZ ute air-bagged
    By Corbs1234 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-03-2010, 11:18 PM
  5. rear bagged vt price
    By justcruzzinn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2009, 10:36 AM
