Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Like Tree2Likes
Thread: 500rwkw vy clubsport
    Blown Rattler is offline Rattler
    2004 VY SII HSV CLUBSPORT
    Apr 2011
    Darwin
    Default 500rwkw vy clubsport
    Hey guys,
    Alot of you may know my car from other forums, but if not she's a 2004 SII VY HSV Clubsport. I purchased her new back in Dec '04 and she has gone through quite a few changes since then!
    She is now on her last "modification run" as tranforming her into a "driven" showcar! The only thing that will be recognisable from HSV is the build plate and the badge on the bonnet.
    Why have I gone this far?
    We took her to Summernats 21 and she made the Top 20 in the Street Car Class out of 487cars on her engineering alone! Still having stock interior, paint and boot and we didn't win any trophies, so decided there and then that the next Summernats we enter, we will be taking home a trophy of some sort!
    It's been nearly 2.5yrs of hard work building her into what she will be as everying has been customized by hand (nothing "bolt on" off the shelf)
    The builder used to build horse and cart carriages in Central Queensland and is amazing with his hands!!
    The thing I wanted with Rattler is for her to be fully street legal and that has NOT been easy but we have done it!
    She is booked for Motor Ex in Sydney July 23&24 2011.... so fingers crossed!
    Here is her modification sheet................
    FULLY STREET LEGAL
    2004 VY SERIES II BLOWN HSV CLUBSPORT
    RATTLER
    Built by Custom Commaro Concepts
    ENGINE
    6.7LTR - 410CI
    Higgins Heads
    Eagle Crankshaft with steel 4.000 stroke
    Eagle H Beam Rods
    Diamond Forged 4.000 pistons
    GM Performance 6LTR cast iron block (decked, honed, chemically cleaned, balanced and blue printed)
    Torrington Rollmaster timing kit
    ARP main studs and balancer
    Clevite H Series Conrod and Main bearings
    Cometic .074 Head gaskets MLS
    Billet Camshaft 410A Hyd Duration @ .050" lift 235 degrees Value lift .561" Lobe 114 degrees
    Crane 1.7 Roller Rockers and hardened pushrods
    Starr pyramid manifold & oversized cooler core
    Voodoo 8rib stainless steel pulley kit
    8rib belt
    Burnout King twin thermo fan radiator
    Meziere Electric Water Pump
    PWR Power Steering Cooler
    INDUCTION
    3.3LTR Whipple Twin Screw Blower
    FUEL
    2 x 044 Motorsport fuel pumps
    Custom 15ltr surge tank
    60lb injectors
    Aeromotive fuel rails
    Aeromotive fuel regulators
    DIFF/SUSPENSION/BRAKES/TRANSMISSION/CHASIS
    Diff Technics 31spline IRS 9" (Billet Detroit Locker with 2.8 gears) with cooler
    BMR CV shafts
    BMR subframe connectors
    Billet stub axles
    3" chro-moly tailshaft
    Tailshaft loop
    Tein 16 point fully adjustable coil overs
    Harrop Ultimate brakes with 381mm cross slotted front disks with 6spot calipers/Harrop 355mm cross slotted rear disks with 4piston callipers
    Summit Racing T400 with 2400 Dominator stall convertor
    EXHAUST
    1 7/8" CNC coated extractors into full 3" Difillipo stainless steel exhaust with stainless D&T resonators
    WHEEL & TYRES
    Chip Foose Shockwave 20x10" and 20x8.5" with 305 and 245 rubber respectively
    INTERIOR
    Full custom Ivory & Black leather Lotus interior
    Full custom Xmplar sound system
    In-Car PC w/ 7" touch screen
    VE R8 steering wheel
    Push start ignition
    Coupe 60 rear bucket seats with rear harnesses
    Haltech Digital Dash
    Custom Trans shifter
    CUSTOM
    House of Kolor full back to bear metal respray (Midnight Blue)
    Front vented guards and rear vented doors for brake ducts
    Front and rear brake ducts
    Coupe 60 front air dam and rear bar
    Carbon fibre wheel arches
    V8 Supercar rear wing
    Fibreglass/carbon fibre vented bonnet
    VE chrome door handles
    Auto opening tail light for fuel filler
    Carbon Fibre inner guards and firewall cover
    Audi R8 LED headlights
    Billet front strut brace
    Full audio boot install
    Rear strut brace
    Battery box under rear console
    Ice box in radiator support panel
    Engine bay fogger system
    Emergency fire control button
    Remote fire extinguisher
    All wiring under bonnet hidden
    Relocated ABS system
    Mini tubs
    6 point rear roll cage
    Factory detailed under body
    Fuel/Power cut off switch
    POWER
    503RWKW @ 12lb boost
    COST
    $300,000 and counting
    BUILD TIME
    On and off for 6yrs (daily driver)
    THANKS TO
    Wayne and the boys at Custom Commaro Concepts, NSW
    Ren at Xmplar Audio, WA
    Frank, Mick and the crew APS Service Centre, VIC
    Mick at Rev It Up Performance, NT
    Denny at D&T Exhausts, NT
    Deano the painter
    Here are a few photos of her throughout the years
    All I can show you now is the new colour, the rest you will have to wait for, sorry
    I will keep you updated with her progress
    Scotty
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    ****drooool****
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Absolutely amazing. I prefer Red VY Clubby's but this looks wicked!
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    While I can appreciate the work gone into it, the first pics make it look the best...
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Apr 2011
    Darwin
    Appreciate the comments guys.... here are a few more "snap shots"
    A few older shots.......
    TAC Inspectors
    9"
    Standard 245 wheel and tyre on left and new 295 on right
    New Harrop Monster disks compared to the Harrop Ultimates
    Caliper difference
    The work begins
    [img]
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
    Big_Simmo's Avatar
    Big_Simmo is offline Great White Cranberry
    WM 6L Stateman
    Apr 2010
    VT V8 Calais
    Mar 2007
    So you have come over from the other commodore forum have you? Been lurking on there a while looking at this, well done.
    50LTRv8
    2005 VZ Acclaim
    Jul 2009
    Northern Beaches, Sydney.
    Apr 2011
    Darwin
    Quote Originally Posted by 50LTRv8 View Post
    Yeah mate, I don't wanna bag the other forum but there are alot of d!ckheads on there!
    So far the comments and people on here have been great!
  15. #15
    minux's Avatar
    Feb 2005
    Quote Originally Posted by Blown Rattler View Post
    Lot of ########s here too mate
    One is posting right now
  16. #16
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Love everything on this car apart from the body work.
    Those Harrop brakes... *drools* and the rear tyres... just awesome!
  17. #17
    Supercharged VU SS
    Feb 2006
    The Shire
    well its about time you came over, there aint as many wankers on this forum, but only just.
    been watching this since it first went in to get the work done. love it
  18. #18
    92 vp executive v6 auto
    Jan 2010
    deception bay queensland
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    i love it mate. got any vids of the beast?
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
  20. #20
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Damn, some serious mods there. Well done mate.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
  21. #21
    Apr 2011
    Darwin
    Thanks guys.... for videos if you search "RATTLER HSV" on Youtube there are a few there
  22. #22
    97VT SS super6,daily 05 holden barina(opel)!!
    May 2009
    Gotta say m8 ,done a fantastic job with the beast looks mint : )
    Also check my ride,sitting on HSV R8 19's
    " And on the Seventh day ,GOD created Commodores!!!! "
  23. #23
    Apr 2011
    Darwin
    Well, I've decided to show you guys a before/after photo of the drivers side engine bay. I have received quite a few photos in the past few months and this will be the only one I put up until Summernats
    Not long to go now
    Before
    After
  24. #24
    vy executive s2
    Jul 2008
  25. #25
    GRPABT1's Avatar
    GRPABT1 is offline Jakstas' Warden
    VN shitta
    Sep 2010
    The ville
    Man, it really is hard to make those later model engine bays look good isn't it.
    Cheap, fast, reliable.....you only get to choose two.
  1. Differance Between 05 VZ Clubsport & 05 Clubsport R8
    By Nayla in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-11-2010, 10:22 AM
  2. vt clubsport rear vy clubsport side skirts?
    By nathan549 in forum General
    Last Post: 27-10-2010, 04:03 PM
  3. [SA] VX Clubsport Bodykit & VR Clubsport Bodykit - Complete Kits
    By OnionbulbR8 in forum Parts And Other Items For Sale
    Last Post: 30-03-2010, 07:36 PM
  4. VP SS/Clubsport ECU
    By ovp92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-12-2009, 07:37 AM
  5. VS Clubsport 96
    By weedo_86 in forum VR - VS
    Last Post: 13-06-2008, 05:45 PM
