Page 1 of 14 1234511 ... LastLast
Results 1 to 25 of 348
Like Tree94Likes
Thread: nathans VY Calais - 'Calais 2.0'
    nathanVY's Avatar
    nathanVY is online now need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Wink nathans VY Calais - 'Calais 2.0' - VY GTS 19s, Tint, Stereo, Exhaust
    Got this absolute BABE of a car for NINE GRAND. FREAKING STOKED
    Year: 2003
    Odo: 123, XXX
    Colour: Navy Blue
    Engine: 3.8Ltr Ecotec, Custom Tuned
    Transmission: 4sp Auto
    Exhaust: Pacemakers, 2 1/2" Cat Back
    Diff: Standard 3.08 Single Pegger
    Electrics: Power Windows, Cruise Control, Climate Control, Full Electric Seats
    Interior: Blue Leather Seats & Door Trims
    Wheels: Genuine 19" VY GTS, 245/35/19 Nakang rubber.
    Stereo:
    - JVC KW-XR810 Double Din, Bluetooth H/U
    - JBL P660C 6 1/2" Splits Fronts
    - JBL GT5-S265 6 1/2" Coaxial Rears
    - JBL GTO 75.4 - 4ch Amp
    - Option Audio OAK1200 Mono Amp
    - JL Audio Twin 12" W3D4 Subs
    - KnuKonceptz 4Ga Wiring
    Mods
    - King Springs SSL All Round, KYB Shortened Struts & Shocks
    - 35% / 18% Tint
    - LED Lighting Conversion
    - Enclosed Pod Filter (MACE CAI)
    - Mace 25mm Manifold Insulator
    - Mace 12mm Plenum Spacer
    - CREE LED Reverse Lights
    - 6000K Foglight HIDS
    - 6000K Low Beam HIDs
    - VZ Calais Tail Lights & Reflectors
    Plans
    Engine:
    - Turbo or S/C?
    Auto:
    - Some short of shift modifications
    When I Got Her:
    Things that need fixing:
    - Needs new wiper blades *done*
    - Bonnet struts *done*
    - Clean throttlebody *done*
    - Drivers seat plastic broken *replaced*
    - Shifter boot worn *replaced*
    - Intermittent alternator fault *voltage regulator replaced, 115,XXXkms 30-1-12 *
    - Idler pulley below the coil packs noisy *replaced*
    - Change castor rod bushes *replaced*, 118,XXXkms 13-2-12
    - Rocker cover slight leak
    - Ashtray doesn't closer properly *fixed*
    - Glovebox droops down a bit on the left *fixed, replaced rubber stoppers & holding clips*
    - Climate Control on HIGH occasionally the fan drops out
    Servicing, etc
    - Engine oil & filter, transmission oil & filter, air filter 114,XXXkms - 20/12/11
    - Mace manifold insulator & plenum spacer fitted, injectors recoed, plenum & throttlebody cleaned 116,XXXkms - 12/2/12
    - Fuel filter & brake fluid changed 116,XXXkms - 13/2/12 (next brake fluid change, 13/2/14)
    - Pacemakers fitted, plugs & leads changed at 117,XXXkms - 4/3/12
    - Oil & filter changed 120,XXXkms - 7/4/12
    - Wheel alignment 120,XXXkms - 21/4/12
    Big_Simmo's Avatar
    Big_Simmo is offline Great White Cranberry
    WM 6L Stateman
    Apr 2010
    elmaso's Avatar
    elmaso is online now PARTY AND BULLSHIT!
    VR Calais
    Jul 2010
    soooo pretty! makes me think of going out and uppdating lol.
    so, wheres the name change nathanVY hahaha
    Drawnnite's Avatar
    Drawnnite is online now Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    i think it should be "NathanCalais" =P
    looks tops Nath. keep up the awesome work.
    sounds like you have a good plan for it (sunroof it already =P)
    now give us some more inspiration to upgrade our cars.
    and did you get those pictures on the old car before she drove out the driveway?
    and will you get some of this new car (you know the ones... =P )
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    Holden commodore VX S Pack
    Apr 2010
    Bacchus Marsh Vic
    Wow nice work man, when you said you wanted a calais, didn't think it was gonna be this soon..
    The blue leather is sick man
    [SIGPIC][/SIGPIC]
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Cheers guys, really stoked on it. So blessed.
    A calais is worth every cent. There is just no comparison to a VY and a VX! The VY is MILES MILES MILES ahead of them.
    Not sure if i'll change my name or not... the old thread is still there so I may just leave it as is.
    Blue leather is awesome too haha, and the bushes are actually in good nick! The front end is really really tight, handling is excellent, corners great. Unlike all the other standard calais' i've driven which just had MEGA body roll.
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    That is a nice pick up for $9k
    Ill be watching the mods on this silently from the corner. Congrats buddy.
    Dave.
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by some_guy View Post
    Dave.
    Cheers man! Was thinking about it last night and the list isn't even that long. Calais already has all the good stuff so you don't have to put it there.
    some_guy's Avatar
    VR SII Exec.
    Apr 2009
    brisvagus
    Seeing how tastefully you put together that VS im sure this will look just as elegant.
    The sunroof would be a fantastic centrepeice though.
    97 WRX AWD
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Lol, I started the modding this morning, by removing the number plate cover (hunter holden nsw)
    VRCALAISS is offline Banned
    94 VR CALAIS 3.8L V6
    Jan 2011
    Morayfield,QLD
    so putting chev badges on her lolol just kidding.
    sent from tapatalk using your mothers phone.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by VRCALAISS View Post
    Jan 2011
    Morayfield,QLD
    Quote Originally Posted by nathanVS View Post
    point taken lol.
    spud_22's Avatar
    spud_22 is online now Ruled by the P
    95 VS Berlina
    Nov 2010
    WOW just about s*&t my pants when i saw the link on the VS thread. Wicked pick up and i cant wait to see how it turns out.
    3.08 LSD, 1.9.1 High Ratio Rockers, MACE CAI, Spacers
  15. #15
    despo's Avatar
    despo is offline V Fast S furious
    vs series one
    Jun 2009
  16. #16
    Essassin's Avatar
    Essassin is offline Bends spacetime
    VY S Sedan, E36 318is Coupe
    Oct 2010
    Limbo
    Welcome to the club!
    I think the change you will enjoy the most is the interior...SO much better than the VT/X or VS for that matter.
    Very nice car mate...look after her
  17. #17
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    thanks everyone! loving it.
    took the towbar off today so that's for sale lol.
    next on the list is to carbon clean the plenum and get some sort of better air filter going on... probably a mace cai.
    interior definitely owns everything holden has ever done!!
  18. #18
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Looking sexy man! when you sent the first pic to me when you went to look at the car I knew you would be buying it straight away! , now hurry up and get that fugly yellow NSW plates off and get some nice black n white VIC ones ;P
  19. #19
    Dan VS 231's Avatar
    Dan VS 231 is offline Ell Sixty Seven
    VY Calais L67
    Jun 2008
    Perth W.A.
    The interior is an interesting look. I also own a Vespers Blue (718H) 2003 VY1 Calais but mine has the shale (beige) leather interior... and an L67. Either way I thought the VS Calais looked sweet considering Ive owned 3 cars that have all been Calais' and started with a series one VS myself your definately on the right path.
  20. #20
    1996 Holden VS Berlina Series II
    Jan 2011
    Nice buy man, very clean with low km's. Supersports would look sweet.
    Further down the track, go for the VYII Calais body kit and VZ Calais tail lights. It'll clean up the overall look even more.
  21. #21
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Still unsure of this Nath. Doesnt have the appea the VS had..ill miss you v 1.0.
    Let the mods begin though.
    Will be an interesting build.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
  22. #22
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by Trayner View Post
    yeah lol! nsw plates won't be going for a while though unfortunately the rego is pretty long and i intend to use it . unless i have some money bags fall from the sky and ill do the rwc early.
    Quote Originally Posted by Dan VS 231 View Post
    Nice, IMO Calais is almost the only ones worth getting. L67 would be nice, how does it drive/ compare to an L36?
    Quote Originally Posted by KrisG View Post
    Yeah definitely, was looking at that before I even bought the car lol. VYII If anything because the VZ Bonnets and Front guards are all different, too much of a mission.
    Quote Originally Posted by Wombles View Post
    Haha, the VS is tougher at the moment but just wait...
    Enjoying driving this one so much more than the VS. Definitely needs and exhaust and a cai though...
  23. #23
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Ill be waiting.. And watching. Everyday. For updates like v 1.0 had.
    You got this one so quickly!
    My Commy
    Discuss.
  24. #24
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Yep lol, the VS's roadworthy and sale took a good 2 weeks and I was looking at cars the whole time hahah.
  25. #25
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Trust you to get a Calais to..
    Hows she drive anyways? Putting it against v1.0
    My Commy
    Discuss.
  1. nathans VS Calais
    By nathanVY in forum VR - VS
    Last Post: 19-03-2012, 12:11 PM
  2. [VIC] SWAP - SSL IRS springs for VT Calais door trims/Calais suede dash kit
    By sxc_sound in forum Swap / Wanted to Buy / Trade
    Last Post: 13-02-2011, 11:05 PM
  3. Replies: 5
    Last Post: 07-02-2011, 11:01 PM
  4. [SA] [WTB] VX Calais Chrome Strip and possibly VX calais aftermarket/genuine monaro lights
    By Robertoe in forum Swap / Wanted to Buy / Trade
    Last Post: 31-10-2010, 04:29 PM
  5. [SA] WTB VL Calais Stock Radio/Casette, Vl Calais Badges
    By reids22 in forum Swap / Wanted to Buy / Trade
    Last Post: 18-08-2010, 05:30 PM
Tags for this Thread
