DevilDRake
Braaaap
- Oct 14, 2009
- 1,161
- 60
- 48
- Age
- 31
- Location
- Skye
- Website
- www.devildrake.deviantart.com
- 2006 VZ SS 6L Ute
Firstly, hopefully I stay with this car haha - I suppose if my ute never got written off this wouldn't be happening.
Tried out the Subaru but ended up having endless expensive problems, so back to the Holdens!
Model: 2004 VY Series II S Manual
Colour: Quick Silver
Engine Type: Ecotec 3.8L
Gearbox: 5Spd Manual Getrag Factory
Kilometers: 192,xxx (When I bought it - Blew up at 194500) - New engine fitted with 155xxx km's @ Odometer 194500
Stereo: See below
Mods/Wishlist List:
Legend
D = Done
O = On Order/already have but not installed
X = Coming up next!
Engine:
[D] Rear main seal - 24/10/15
[D] 1.9 Roller Rockers with pushrods - 24/10/15
[D] New Rocker cover gaskets - 24/10/15
[D] Raptor Supercharger with Lightened internals - 28/11/15
- Billet Impeller (faster & higher boosting)
- Liquid cooled charger
[D] New engine fitted - 29/12/15
[D] New engine mount - 29/12/15
[ ] Mace airbox enclosure
[ ] 82 Degree thermostat
[ ] 69mm Throttle body
[ ] Reverse Plenum
[ ] Intercooler + piping
Drivetrain:
[D] Xtreme HD Clutch with Single-Mass Flywheel - 24/10/15
[D] New Clutch Slave Cylinder - 24/10/15
[D] ANOTHER New Clutch Slave Cylinder - 29/12/15
[D] Getrag Short Shifter - 23/10/15
[D] Tailshaft Centre Bearing - 24/10/15
[D] Tailshaft rubber donut - 24/10/15
[D] Both gearbox mounts - 24/10/15
[D] Clutch and gearbox oil flush [REPLAC - 24/10/15
[D] Gearbox oil flush - 29/12/15
[D] 3.46 Reconditioned LSD - 29/10/15
[ ] Gearbox extension housing seal
Exhaust:
[D] Pacemaker Supercharged extractors PH5061 w/ 2.5" Outlet - 27/10/15
[D] 2 x 2.5" 200CPSI Venom Cats - 27/10/15
[D] Custom Twin 2.5" Y Pipe into twin 2.25" Exhaust with tips - 27/10/15
[D] Bosch Oxygen Sensors - 27/10/15
Fuel/Ignition/Tuning:
[D] New NGK Spark plugs [REPLACED] - 4/11/15
[D] New Spark plugs - 29/12/15
[D] New NGK Spark plug leads - 4/11/15
[D] Changed coil pack and DFI module - 5/11/15
[D] Tuned PCM - 6/11/15
[D] 36lb injectors - 6/11/15
[O] Walbro 255L High-Flow in-tank Fuel pump
[ ] High-Pressure fuel regulator
[ ] Custom Tune
Body:
[D] Custom plates - 15/10/15
[D] Colour match L/H Mirror - 16/10/15
[D] SS headlights - 16/10/15
[D] Foglights - 21/10/15
[D] Bonnet struts - 24/10/15
[D] VT SS 17" Rims - 31/10/15
[X] 15% Tint
[ ] Front bar respray
[ ] R/H Rear door respray
[ ] Touch up R/H side skirt
[ ] Foglight wiring + Relay
[ ] Slimline weather shields
[ ] 20" Rims
[ ] Bobtail lip w/ Brakelight
[ ] Tow bar cover
Suspension/Brakes:
[D] Rear swaybar bushes - 24/10/15
[D] Front Swaybar Link pin kit - 13/11/15
[ ] DBA T2 Front/Rear Rotors
[ ] Brake pads (unsure)
[ ] New Strut top bearings
[ ] King Spring SL's front/rear
[ ] Shortened Front/Rear Shocks Struts
[ ] Rolled Guards
Interior:
[D] Floor mats - 18/10/15
[D] New instrument cluster glass - 19/10/15
[D] Phreddy conversion 6/11/15
- Digital Speedometer
- Speed correction from 3.08 to 3.46 Differential
- Blue Switches throughout car
- Blue with red redline on cluster
- Cluster morphing needles blue to red
[D] Speaker grills in doors - 8/11/15 (still need rear r/h speaker grill changed)
[D] SAAS 2 gauge pod - 14/11/15
[D] Autotecnica electrical Volts gauge - 14/11/15
[D] Autotecnica electrical Boost Gauge - 14/11/15
[D] Blue Leather seats - 23/11/15
[D] Blue Leather door trims - 23/11/15
[D] Satin door handles - 23/11/15
[X] Replace glovebox rubbers
[ ] Parcel shelf without 6x9 holes cut.
[ ] Boot lid carpet
[ ] New gearshifter boot
Stereo:
[D] Subwoofer amp - Responsive Precision 1000WRMS into 1ohm - 14/11/15
[D] Subwoofer - 15" American Bass XFL1522 1000WRMS into 1ohm - 14/11/15
[D] 1750WRMS Stinger wiring kit w/ 175A fuse - 14/11/15
[D] New headunit - Kenwood DDX-4015BT Touchscreen - 14/11/15
[D] Rewire new headunit and fix existing wiring - 14/11/15
[D] Fit Doubledin VY facia kit - 15/11/15
[D] Unwire parcel shelf 6x9 - 15/11/15
[O] 2 x 12" Polk Audio MM1240 Subwoofers
[ ] Change current 6.5" Clarion splits for something better
[ ] 6" Rears
[ ] 4 Channel Amplifer
Following before and after pictures:
BEFORE Stereo
After
BEFORE
After
BEFORE
After
BEFORE
After
BEFORE
After
BEFORE
After
BEFORE
After
Stereo: See below
Mods/Wishlist List:
Legend
D = Done
X = Coming up next!
Engine:
[ ] Reverse Plenum
Drivetrain:
Exhaust:
[ ] Custom Tune
Body:
[X] 15% Tint
[ ] 20" Rims
[ ] Tow bar cover
Suspension/Brakes:
[ ] Rolled Guards
Interior:
[ ] Boot lid carpet
Stereo:
[ ] 6" Rears
BEFORE Stereo
After
BEFORE
After
BEFORE
After
BEFORE
After
BEFORE
After
BEFORE
After
BEFORE
After
