| VY - VZ - WK - WL - V2 Post pictures and details about your VY Commodore. |
27-09-2008, 04:17 PM
Ashbox
Ride: VZ SV6
flairing the end will hold it in the box more so it doesn't fall out.
what do you mean different setup to the vz, the air box will be on the same side as the vy and yes it will prob take some time for the ecu to recognise more air coming in
__________________
For more info Click Above
WTB: VZ SV6 or SS Grille
Ride: VY II SS
I doubt flaring the end does anything at all.
I believe it just makes it look like the standard funnel.
27-09-2008, 08:44 PM
Ride: VY Commodore S
That's what i figured...
On the vy the box is on the same side obviously but the snorkel is different. And like everyone said the coolant reservoir is right there so i decided to put the hole on the side rather than the front.
Has anyone else done this mod to a vy?
03-10-2008, 03:00 PM
I'm No Superman...
Ride: 2003 VY S1 Exec
How have most people done theirs on a VY? As I have a VY s1 which will be getting this mod very soon, but im not sure to put the hole on the front, or passenger side, or both, of the air box.
Cheers lads
03-10-2008, 10:20 PM
First Car Bought!!!
Ride: VYII Berlina, '97 Lancer
The VY airbox looks rather hard to do and a bit of a waste of time as the hole you cut out is rather small so you wouldn't get much of that induction growl.
__________________
A Commodore is a passion. Anything else is just a car
Duckman: "The Duckman says his holden rocks."
Other Guy: "Will you always be referring to yourself in third person?"
Duckman: "The Duckman says yes."
09-10-2008, 11:59 AM
Handles like a virgin...
Ride: 2005 VZ Commodore SV6
Hey guys, I've never looked under the bonnet of a VY, but I thought the airbox in a VY was the same as a VZ. Not Hard to do at all. I was able to stick both the MCAI shroud and airbox in a vice when I was working on it, and cos its really soft plastic it just springs back into shape. Soft plastic also means drilling is very easy. I marked out my holes, used a small drill bit (about 0.5cm diameter), drilled every cm then held the drill on and easily moved from one hole to the next, using it as a hole saw.
This mod seems to work well with the alloytecs, maybe the ecotecs respond differently to this mod.
Anywway, was washing my car the other day and my mags are just filthy and I'm struggling to get them clean. Can anyone recommend a product to clean my mags before I polish them, or does it just take a little more elbow grease to clean them.
09-10-2008, 09:22 PM
LS1,thats how i roll.....
Ride: VY LS1 6speed,daily: EB Fairmont I6 on GAS
armourall wheel cleaner works well. squirt on, hose off. i use an old soft scrubbing brush as well. get all the brake dust off etc. then clean and chamois.
09-10-2008, 10:03 PM
went to summernats 09!
Ride: Cammed Y-Series Clubsport
just have your rims painted black  im thinking about it.
10-10-2008, 08:08 AM
Donating Member
Ride: VZ R8 M6
i had my sv6 rims painted black unfortunately doesnt give that appearance of clean that you would hope for
__________________
Quote:
Originally Posted by Skitz
Go ahead with the SS badges,you will reap the benefits.
I have put SS badges and the kit on my VE Omega and when I go cruising and rev it past the girls.........well what can I say,they have drool running down their face.I chuck a U-turn and they say ''Nice car'' and I say ''It's an SS,jump in''.
10-10-2008, 09:46 AM
I did toy with the idea of painting them gun metal grey, a similar colour to the Lamborghini Reventon's mags:
10-10-2008, 09:49 AM
Off to Summernats 22!
Ride: Ride: Ride: Ride: Ride: Ride: Ride: Ride:
Hey buddy,
Those mags aren't grey, they're black with carbon fibre inserts.
Well at least that's what colour mine are lol
__________________
Listen here, you snapper heads....
10-10-2008, 05:47 PM
Ashbox
Ride: VZ SV6
mmm, black mags, how long did it take you to get them done? sorry for the hi-jack
i can't be bothered buying new rims just yet.
__________________
10-10-2008, 06:59 PM
Thanks for pointing that out VT-565. Ok I guess the colour I'm looking for is similar to what the HSV Coupe GTO's had.
11-10-2008, 09:47 AM
Ride: VY LS1 6speed,daily: EB Fairmont I6 on GAS | | | |
