If you used the PCM power wire the ECU might get upset.. but if you use an ACC 12v wire (like the cigarette lighter) I can't see why this would cause problems. It's no different than having it permanently plugged in via the normal lighter plug.
The only thing that could happen is the fuse could blow if you had a high current draw through the lighter socket, and using the TomTom, but I doubt the TomTom draws that much current to really matter.
LinkBack URL
About LinkBacks
