how do i undo the belt on my vz i need to change the water pump ?? thnx.
VR EXECUTIVE
We had some good times
The idler pulley just under the alternator. There is a tension bolt just loosen it, this will free up the belt.
The Blue One
Grab yourself a 1/2 inch rachet - that will plug directly into the tensioner pulley without a socket and pull the tensioner towards the right side of the car - flick the belt off the alternator and you're in business. No need to undo bolts or anything
