G'day,
Had the drive belt off the car yesterday. So I decided to check the various drive pulley's. All where fine apart from the water pump pulley. Pump shaft has movement horizontally and vertically a well as in and out. Pump is not leaking or making a noise. My questions are, should I replace it? Is it about to fail? Do the Alloytec pumps have this run-out from new? Car has 110k klms. Any advice much appreciated.
mine started leaking, at about 80,00km turned out it was only the casting plug but anyway it had a lil play in the shaft, installed the new one, it had more play in it then my old one, so went back to holden showed them, then we went around and checked similar cars and they where the same,
so im guessing its something in the design of them,
just keep an eye on it
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
