Results 1 to 7 of 7
Thread: Need Advice Removing Bolts
    Burger's Avatar
    Burger is offline Burger
    VZ SV6
    Mar 2009
    Hills District
    Default Need Advice Removing Bolts
    Hey guys,
    Just in the middle of installing a CAI on my VZ. Have to remove the torx head bolts that secure the filter box but the buggers are stuck fast! Any suggestions?
    VZ SV6
    Feb 2008
    Bayside Melbourne
    Dont have to remove the bolts at all
    just give it a tug and it'll come out - those bolts only act as a holder for the rubber grommets. Just pull the airbox straight up out of the bay and it should come out
    Burger's Avatar
    VZ SV6
    Mar 2009
    Hills District
    Got the air box out but the filter surround bolts onto the wheel arch thru those bolt holes
    VZ SV6
    Feb 2008
    Bayside Melbourne
    when you say you got the airbox out do you mean the top half and the bottom half?
    VZ SV6
    Feb 2008
    Bayside Melbourne
    There should be three bolts holding the main section of the airbox down - these will be the colour of your chasis and they are the star pattern. If they are the three you are trying to undo then you don't need to. Just pull the airbox up, it may need a bit of force but it'll work
    Burger's Avatar
    VZ SV6
    Mar 2009
    Hills District
    Both, but after several hours of alternate heat and WD40 I've finally got the bolts out. Can't believe how tightly they were in. Thanks for your help anyway.
    VZ SV6
    Feb 2008
    Bayside Melbourne
    nurries mate
  1. ARP bolts
    By DANNY8 in forum V8 Development and Modification
    Last Post: 11-03-2009, 02:37 PM
  2. Flyweel Bolts S1 (6 bolts) How Do i Remove? Reverse or Normal?
    By social in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2009, 10:54 AM
  3. Removing broken bolts?
    By DANNY8 in forum General
    Last Post: 06-09-2008, 09:01 PM
  4. Removing Rounded Bolts
    By fitzy2005 in forum General
    Last Post: 26-10-2006, 07:34 PM
  5. Help/advice needed removing dash
    By vxcom2000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-05-2005, 11:58 PM
