Results 1 to 14 of 14
Thread: Locking Automaticly when sutting drivers door
    '04 VZ Executive, '98 EL Falcon, '96 NF Fairlane
    Jul 2008
    Blue Mountains, Sydney, NSW, Australia
    Unhappy Locking Automaticly when sutting drivers door
    Hey everyone
    Well when I shut the drivers door the car locks every door then i have to unlock it. this doesn't always happen but today it happened until I started the car then it stopped.
    This would be good if I wanted the door to lock lol.
    Luckily when I have had the keys in the car I was at home so I used the spare key to unlock it.
    Why does it do this and how could I fix it or how much to get repaired?
    thanks for help in advance.
    [Linkin Park] Concerts:
    [20.10.2007, Sydney Entertainment Center, Sydney NSW] [11.12.2011, Acer Arena, Homebush Bay, NSW] [15.12.2011, Acer Arena, Homebush Bay, NSW]
    Vehicles:
    [2004 VZ Holden Commodore Executive V6] [1998 EL Ford Falcon GLI Manual Inline 6] [1995 NF Ford Fairlane Ghia Inline 6]
    bludeck's Avatar
    bludeck is offline Wishlist = Blowa
    VZ Wagz
    Dec 2007
    Gold Coast
    when you turn your ignition on, watch the screen and wait to enter the options menu, theres an option to lock the doors when placed in gear and to unlock when parker, anti car jacking feature. look in the menu and change it. theres a few options in there.
    Jul 2008
    Quote Originally Posted by bludeck View Post
    Its not that its turned off. you shut the drivers door it locks the car is not even on the key can be in the ignition with out accessories on or just in the car or in my pocket outside the car it locks automaticly. Luckily at the petrol station when I left the keys in the car i had my window down so I got the key and unlocked it. Also no other option has anything to do with shutting the drivers door with automatic locking. But thanks anyway
    Forgot to add to my first post that if I shut the door gently it doesn't lock automaticly and the holden systems check comes up with ok.
    Also I have a question the car is not garaged at the moment and in the Blue Mountains in NSW have had constant rain that had been very heavy could that cause a problem because the error has not happened before the rain?
    Vehicles:
    WK Stato
    Oct 2008
    I think you will find that the snib mechanism itself (the bit you lift to unlock) is sticking half way and the shutting of the door causes it to relock. Spray some crc wd40 whatever on it and see if it helps, my guess is it will
    MY07 VE Calais V
    Sep 2005
    Gold Coast
    I had similiar strangeness a while ago with my VZ which seemed to revolve around shutting of the drivers door, the solution for me was to unlock and lock the car a few times with the spare key. One of those WTF things.
    Jul 2008
    Quote Originally Posted by crew chief View Post
    Its not that still does it made sure that the lock thing was up completely and a bit of WD-40 but still did it and it only stops if i turn accesories on.
    Vehicles:
    vs commodore sedan
    Jul 2005
    aftermarket alarm installed??? or else maybe a short either in the door lock or the cableing between the door and the car my sv6 did it after all this rain we have been haveing up here in the moutains turned out the door lock was full of water shorting out
    SVZ and VK Calais
    Feb 2009
    Brisneyland
    Jul 2008
    Quote Originally Posted by danny1987 View Post
    factory alarm. it hasn't done it since the rain has died down
    Vehicles:
    VZ 3.6
    Jun 2009
    LowVtWagon's Avatar
    LowVtWagon is offline LowVtWagon
    Holden VT Acclaim Wagon
    Dec 2008
    country
    i've had the opposite happen. sometimes when i get to work and have to get out and unlock the gates, i open the drivers door and the other doors decide to unlock themselves. this is while the car is running. (vt acclaim wagon)
    VZ Calais
    Jun 2009
    same problem here. when it rains a lot the whole car locks itself when you shut the door.. very bad if you leave the keys in it.
    Commodore Wagon 2007
    Jun 2009
    Quote Originally Posted by LowVtWagon View Post
    HI, new to site. We have a VZ Acclaim wagon, and can't get the horn to beep if a door is not fully closed when we click to lock the doors. We have to check them manually. Do you have this problem Any suggestions? Thanks
    vt ss 5.7 ls1
    Jun 2009
    Auckland New Zealand
    Hi new to site as well same thing happened to me just this morning! Started up car got out shut the door BANG! all the doors locked oops! Luckily I was at home and used the spare keys to open it I have also noticed the door mechanism is getting a little harder to open as well, dampness getting in maybe! I will try the crc thing and see if that helps
  1. [WA] Fs: Vt white drivers side door with window,door skin &mirror - $60 - perth
    By Timzo in forum Parts And Other Items For Sale
    Last Post: 12-01-2009, 07:59 PM
  2. Central locking drivers door
    By JoshsVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2007, 05:12 PM
  3. Central locking drivers door
    By Thommo77 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2007, 08:58 PM
  4. vs drivers door central locking
    By shyvn6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2006, 09:26 AM
  5. Drivers Side Central Locking
    By menzy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2004, 01:59 PM
Tags for this Thread
