Results 1 to 20 of 20
Thread: LED indicators and park lights
    06 SV6
    Mar 2009
    Christchurch, NZ
    Default LED indicators and park lights
    Hi all,
    has anyone had success with LED tail lights/indicators in a VZ? I'm wondering if the blown bulb indication will come up or the indicators flash faster....I would rather jsut fit bulbs than have to do resistors as well to fix the warnings!
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    I'd check with 'the authorities' first if I were you as you might find that the LED's are not ADR approved for road use. Just a thought, might save you some embarrassment later on.
    VZ LS1 Calais A4
    Feb 2006
    Engadine
    Default Leds in a vz
    I currently have LEDs over the rear number plate on my vz calais. When I first installed them I always got the blown park bulb error come up on the dash, but a month later it doesn't have the error anymore. Think it just gave up.
    06 SV6
    Mar 2009
    Christchurch, NZ
    Quote Originally Posted by Benboy View Post
    Thanks mate - have done it all b4 and it isn't an issue here in NZ :-) You guys seem to have mucho tougher/better enforced regs for some things!
    06 SV6
    Mar 2009
    Christchurch, NZ
    Quote Originally Posted by tja_bot View Post
    Interesting......you'd think it simply checks continuously, wonder why it stopped?
    I might just get one replacement unit and try it.
    VZMAX is offline I THE GREAT
    vz svz
    Dec 2008
    I have led's in my number plate lights and parkers, no error whatsoever...and I am seeing lots of cars now-a-days with led parkers and number plate lights so don't think its a big issue...ive had mine for around an year now no problems...
    Ride: VZ SVZ
    MODS: Darkest legal window tint
    3 inch catback exhaust
    Genuine Holden front strut brace
    Xenon blue headlamps & number plate lights
    CAI with POD setup
    NEXT:
    upgrade music system
    VY Equipe S2
    Mar 2009
    I've had blue parkers, red parkers and white parkers and all of them except the red parkers have blown. For some reason the white leds are more prone to blowing up. Never thought of the led side indicator idea. I imagine they would be brighter than the standard wedge bulbs. I've seen red side indicators which were stupid lol. The SMD's are now the better LED's these days, that's why i find works well.
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    For the indicators you will need a relay. I have one that I'm not using.
    EDIT: The sides won't make a difference but the front and rears will (so I noticed)
    06 SV6
    Mar 2009
    Christchurch, NZ
    Quote Originally Posted by Troy711 View Post
    ? Can you explain a bit further plz mate? Do you mean a flasher when you say relay - i.e. a flasher that doesn't go quicker when you fit LED's?
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Wink LED's
    I have used SMD LED's for the repeater lamps and parkers
    with no problem. Although they did fail in under a year
    (poor quality LED's abound!).
    Have also used an array of SMD bulbs for the tail/stop lights.
    Unfortunatly they where nowhere near the luminosity of
    the OEM incandesant bulbs.
    As for indicators you will need a LED flasher or a load
    resistor on each LED bulb to maintain the correct flash rate.
    Once again they might not be as bright as incandesent bulbs.
    You are always going to be taking a chance on LED bulb replacement
    purely because the light fixtures were never designed to work
    with LED bulbs.
    Best of luck.
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Quote Originally Posted by allun View Post
    Yep, fitting LED bulbs will make the car think that the bulb is blown because they draw bugger all current, that;s why they flash fast. All you do is replace the relay with an LED flasher relay. I bought a Narva one and it worked fine but it didn't make the ticking noise.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    you will onyl get park light out, if you own a berlina, calais, stato, caprice etc, lvl2 and 3 vehicles, base specs like, ss, sv6, exec, acclaim wont have the blown light warning
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    the light prob went out cos the light blew.
    Chev badges are an instant fail
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by ashbox View Post
    there is also the re-learn procedure in the owners manual for lights i beleive,
    after a while they must do a check and learn itself
  15. #15
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by andyman View Post
    strange but i suppose it is holden we're talking about
  16. #16
    VZ LS1 Calais A4
    Feb 2006
    Engadine
    Nah they still work
  17. #17
    Nux
    Nux is offline
    2006 VZ Executive
    Jun 2009
    A mate got booked for blue LED parkers, copper wasn't happy to see blue lights on a non cop car, also red is the same. Green is supposed to be only to indicate fridge on for a semi, but there are lots of people with colours so the risk is yours. I have green parkers in my kenworth, thinking about doing the dore as well?
  18. #18
    vzlumina's Avatar
    vzlumina is offline 01/05 VZ Lumina AKW-989
    '05 VZ Lumina, '99 CR125
    Aug 2008
    Hey all,
    So if i have VZ Lumina with a 3 window dash what should it tell that is blown?
    Also i have those SMDs in my font parkers, they harldy ever work some times they do somtimes they don't but cant get them out.
    What would be the cause of this ?
    Exidor's Avatar
    May 2008
    Earth. For now....
    Quote Originally Posted by vzlumina View Post
    Hey all,
    Why can't you get the parkers out?
    I'm not afraid.
  20. #20
    vzlumina's Avatar
    Aug 2008
    because stupidly they are just small enough to fit through the whole, but i cant get my hand down there to pull them out on an angle that lets them come out, i tried and now have a blulb floating in my left hand head light
  1. Coloured Park Lights...
    By VR_Project in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2011, 10:40 PM
  2. vt park lights
    By timdawes in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-07-2011, 08:47 PM
  3. park lights shorting out??
    By 122 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-09-2008, 06:00 PM
  4. Park lights
    By holdenmyk in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-02-2008, 05:13 AM
  5. Park Lights
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2007, 10:25 PM
