Quote:
Originally Posted by furrhead
Forgive me but what is a kalmaker?
www.kalmaker.com.au should answer that for you
as for the V6's differences ....
the 175 motor has variable cam timing on the intake cams only, whereas the 190 ALSO has it on the exhaust cams.
Intake Manfiold:
Dual-plenum, equal-length with two-position variable volume control and resonance tuned (190)
Dual-plenum, equal-length with tuned plenum communication orifice (175)
the 190 is also the only motor that has the 5 speed automatic with active select (paddles on the steering wheel) all 175 models (i believe all) have the 4 speed auto (4L60E)
both motors can have the 6 speed D173 manual gearbox.
i hope all this information is 100% correct.
