Results 1 to 10 of 10
Thread: vz calais revs flaring
    2011 voodoo thunder ss
    Jan 2009
    Unhappy vz calais revs flaring
    hi guys. i bought a nice vz calais bout 3 months ago and ever since i got it i noticed that ocassionally when under light throttle the revs will flare by maybe 1-200 rpmn and you can feel the car surging. it is most noticable when in top gear (5 speed auto) and going up a slight incline. anyways i took the car back when i 1st got it and was told it had no fault codes and seemed normal, so i didnt take much notice until the other day when it seemed realy bad, and was doing it in every gear, its definetely noticable but it hasnt logged any codes so im wondering if its a problem with the electronic throttle or auto,, has any one else had this in there vz? any help appreciated cheers
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Coming from a Manual owner, cant really relate to ur prob but ur best bet would be to take to a transmission specialist.
    From the sounds of it, most likely is a fault in the trasmission somwhere.
    Are the gear changes eratic?
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    VZ SV6
    Aug 2008
    i had the surging (ever so slight when slowly accelarating)around the 1700-1850rpm.was due to the variable intake switching over inside the V6.from economy to a shorter run for accelrating.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by baracuda View Post
    that would seem plausable to be
    disconnect it, and see if it does it
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Jan 2009
    yeah i was thinking today it might have to do with the intake, sounds just like yours, does it between 1500-1900 revs or so.. i'l have a fiddle and see what i come up with
    Jan 2009
    Quote Originally Posted by PaulSV6 View Post
    the gear changes are perfect, nice and smooth, which is why i was starting to think it was normal until it started to get worse
    Jan 2009
    was this part faulty? or is it normal? cheers
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    at the back of the manifold, in the middle you will see a round black motor bolted to the top part of the manifold, disconnect the wiring from that and see if it still happens,
    Jan 2009
    Jan 2009
    hi guys, i disconnected that motor the sarvo, with no luck, its still there, the motor on the manifold only opens and closes a flap in the intake at about 4000rpm anyways so i din think it would work, but thanks anways, still got me stumped
  1. Guard flaring
    By holdenhero in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-07-2010, 01:45 PM
  2. vibration/shudder problem @ high revs VZ Calais
    By goodday in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-04-2009, 11:46 AM
  3. calais revs
    By dsnutz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-05-2006, 03:14 PM
  4. VS Calais revs drop at idling speed
    By vsuterus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2005, 01:22 PM
  5. VS Auto Flaring
    By Koontz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2005, 02:20 PM
