Anyone know if you can get a VZ SV6 to default to traction control OFF on startup? Some traction control systems are good - this one isn't.
Cheers guys
Andrew
Sorry i cant help, but can you elaborate on why you dont want traction control at all?
take the fuse out lol easy fixed lol, but how hard is it to just push the button in the middle of the console
Yeah, I automatically press it every time i start up my car.
Once you do it a few times, it just becomes habit.
Well it kicks in for VERY minor traction loss and then takes a few seconds to disengage - very dangerous especially if you are turning right into a main road and have traffic coming at you.
If it kicked out as quickly as it kicked in it would be great but it doesn't.
Anyone know if this can be done?
i have heard on here of a reverse wiring setup
so its off when u start and u push the button to turn it on.
maybe search and u might find it
Forecast For Tonight Is Alcohol, Low Standards And Poor Decisions.
traction control button
u may be able to find out if this guy did end up doing it
Thanks guys
yeh mate he probs changed it from a normally closed contact to a normally open contact on the relay.
so it would be a start to look for the relay, unless ofcourse it doesnt use a relay n its done by electronics, which i suppose it probably is, in which case its alot harder lol.
