Results 1 to 10 of 10
Thread: VZ Spark Plug Change - Now Pinging???
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    Default VZ Spark Plug Change - Now Pinging???
    I just did a spark plug change yesterday on my 2006 VZ Exec. it had some single pointed bosch platinums, and i replaced them with some 4 pointed bosch platinums as thats what I was told to use via supercheap, i doubled checked the book at supercheap n they were the right ones.
    Fairly straight foward, n now i have pinging.
    1. Wrong plugs? or maybe that they are 4 point and not the 1 point ones (1 prong).
    2. Intake manifold leak? ....... when I first put it on it was misfiring, tightened it up a bit and it was fine.
    As I have tuning software, I lowered the timing advance, put some 98 fuel in and still no go.
    HELP
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    VY SV8
    Sep 2008
    did mine 1000kms ago 99 vt exec and one of the plugs outer casing was fractured straight out of the packet, when i torqued it, it fell to pieces i didnt try to start it like that but maybe that might be a problem. took it back got a new one and they go good as now, i highly recommend the bosch fusions quad sparks :P
    Sep 2008
    yea I got the quad fusions...... I redid the manifold and rechecked them........... still pinging.
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    I replaced mine with Fusions.
    No problems to report.
    Although they do have a larger non
    adjustable gap than OEM.
    VZ Skaife Senator & VY SS UTE
    Jun 2004
    impulse sv6 fitted those fusions to his car as well and got pinging in the top end ended up fitting ngk's to fix it.
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    Quote Originally Posted by monaro327 View Post
    yep .
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    +1 for NGK plugs. No experience with them on VZ's but they have always given the best service in my experience.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Maybe they are the wrong heat range?
    A call to Bosch might not go awry.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    vz acclaim
    Jun 2006
    yes NGK are the way to go i did mine today and apart from breaking my tp elec connector shes running like a machine
    TEAM CLOWN RACING
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    tuning making it to lean
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  1. Spark plug GAP
    By Noy in forum V8 Development and Modification
    Last Post: 22-04-2009, 12:54 PM
  2. v8 spark plug gap?
    By HSV472 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2008, 10:55 PM
  3. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  4. Spark plug change V6
    By herkman in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-12-2006, 12:07 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
