Results 1 to 5 of 5
Thread: Power steering fluid leak
    Tuttle's Avatar
    Tuttle is offline stupidity reigns supreme!
    VZ Acclaim
    Feb 2009
    Default Power steering fluid leak
    last week i filled up my power steering fluid as it was vary vary low and i have now looked at it again and there is now half the amount in the little resevoir, does this mean there is a leak or is it due to overflow when it heats up.
    when i filled it i did it when it was hot and up to the max mark so wouldnt think it would overflow.
    any help would be good cheers
    05 VZ Commodore Equipe
    May 2007
    Yea the volume of the fluid does vary quite a bit with temp...but if it was low (well below min) in the first place you might have a leak. Check all the hose clamps, they are not done up that tight at the plant.
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    also (with engine NOT running) run your finger on the inside of the power steering pump pulley and you can tell if it leaking, but i would say its the small pipes that run into the radiator? (not sure where)
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    yeh i knew it would vary but didnt think it would if i looked at it at about the same temp. it was well below the min when i filled it and i am keeping an eye on it now.
    i will have a look at the clamps and what not
    thanks
    VZ SV6
    Aug 2008
    Check clamps on pipe bottom left side engine bay where pipes go to radiator thats were mine leaked tightened clamps good as gold.
  1. Power steering fluid leak - VP
    By LoZzA199 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2009, 11:34 PM
  2. power steering fluid leak
    By VPplayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2009, 03:00 PM
  3. Power steering Fluid leak
    By 410ci in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2009, 02:53 PM
  4. Power Steering or Transmission Fluid leak?
    By DzRBenson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2008, 10:05 AM
  5. VN power steering fluid leak
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-05-2006, 11:23 PM
