Results 1 to 6 of 6
Thread: cannot turn key in ignition even when the steering colum isn't locked
    VZ 3.6
    Jun 2009
    Default cannot turn key in ignition even when the steering colum isn't locked
    Any ideas other than hitting it ?and spraying with lanolin etc
    Nitronic_12's Avatar
    Nitronic_12 is offline Loser of the loser flyby
    VZ Calais
    Mar 2009
    Melbourne!!!
    Try checking the gearstick or handbrake.
    Jesus is my Lord and Saviour
    VZ Calais
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Oh, this happens to me every now and then, but all i do is wiggle it around and back and forth and then it goes.
    vz ss 2006 commodore
    Mar 2009
    Hey,this happened to my ss,it is under warranty so i took it to holden and they replaced the barrel.You will eventually not be able to start your car the longer you leave it
    VZ V8 Calais 285rwkw
    Dec 2008
    Narellan
    Give the key a sharp tap with a hammer, this is only a temporary fix though, as others have stated, you will need to get the barrel swapped out..
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    ur key barrel is goin man, one day just wont turn at all so get it fixed when ya can
  1. cant get ignition to turn!!!!!
    By vxchick in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-05-2008, 09:33 PM
  2. Help needed!!! Can't turn the ignition key!!
    By BaldyA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2007, 07:26 PM
  3. VX SII steering getting stuck mid turn....HELP!!!!!
    By MoSkA in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-04-2007, 06:43 PM
  4. ignition switched to on, cd player doesn't turn on
    By Denno in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-08-2006, 05:18 PM
  5. Key wont turn and acts as if steering whel is locked need help asap
    By gemini in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2006, 11:03 PM
