Results 1 to 15 of 15
Thread: VZ SV6 Problems #3
    GTRwilson's Avatar
    GTRwilson is offline sell me your VY sigs!
    VZ SV6
    Nov 2008
    Default VZ SV6 Problems #3
    Ok yes, another problem thread by me.
    In my other Problem threads, my problems seem to be shared by many others, whereas these i think might be a bit more of, my own bad luck and not a commodore thing.
    Here goes anyway...
    Problem #1:
    After starting my stereo install earlier in the week, i had to remove my rear passenger-side door trim. When doing this, i took out the electrical window switch, among other things. Now when removing my window switch, it fell to pieces in my hands......
    Im lost as to how it goes back together, and if I even found all the pieces. Pic below shows the parts i managed to find:
    http://img196.imageshack.us/img196/236/img4924n.jpg
    http://img188.imageshack.us/img188/4977/img4925l.jpg
    Problem #2:
    I just noticed tonight while working in the back of my car at night, that the rear drivers side interior light doesnt turn on when the interior lights are switched on. As in, when the switch for the light in in the middle, it doesnt come on with the rest, but when turned on permanently by itself, it comes on. I hope that best explains it, if anyone isnt sure what i mean, let me know and ill try to be more specific.
    Problem #3:
    The large panel that covers the rear of my drivers seat seems to be partly broken. It appears the two clip thingos at the top have somehow been snapped off. Im assuming this part is inserted by pushing the broken clips up and then clipping the bottom into place. Question is, is this right, or how do i take this panel off to try and repair it?
    Pic to help show what i mean:
    http://img197.imageshack.us/img197/9624/img4926.jpg
    http://img32.imageshack.us/img32/7306/img4927c.jpg
    Black VZ SV6
    Dec 2005
    same thing happened to me mate
    looks like your missing two small white lugs that go into the back of the switch that push those gold colored contact rockers.
    Pretty easy to put back together if you have those, but missing you will never get it working again.
    I recommend going to holden and ordering a new one, think they are about 20 bucks. No big deal.
    With your rear interior light, it sounds like , either: the wiring is back to front in the switch, or there is a short or earthing problem in the wiring.
    As for your third problem, i have never seen this happen before! I have seen plenty of map pockets half torn off, but the whole panel is a first for me! You may have just find an alternative way to screw it down... or buy a new one.
    Drive it
    Like ya stole it!
    vz sv6
    Apr 2009
    seen it like that mine happen goto holden with it and get new clips for the one at the pack of the seat not sure about the others
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    With the rear window switch, may look at just getting a replacement from the wreckers. Do VY switches fit? only problem with this is, ive had the Phreddy lighting mods done, so ill have to re solder the blue LED into the new switch.....
    Anyway i can tell by looking at the rear interior light, to tell if wiring is mixed up? Not too cluey when it comes to that.
    As for the rear panel on the drivers seat. Does anyone know how it actually comes off? So i can repair it and put it back in.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by GTRwilson View Post
    Putting the rear switch back together shouldn't be that hard!
    Prob be a few clips at the bottom as well, just have a look
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    R32 GTR 360AWHP
    Feb 2004
    Palmyra, WA
    I had same thing happen to me when I owned mine mate, think it was about $5 or something for the plastic clips, just replace em, they are a bitch to take the old ones out and put the new ones in though coz as I remember they are a clip in and they superglue em into place. However once you got em off it's easy street from there.
    Me? I'm the guy who does his job ... you must be the other guy ...
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    Are you referring to the clips that are still holding my drivers seat back panel on? just break it all the way off and replace aye? strange they dont allow you to take them off without breaking them.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Here goes anyway...
    Problem #1:
    Problem #2:
    Problem #3:
    GTR
    I have experienced the same problem as yourself with the switch, but was lucky that it didn't fall apart, just separated top from bottom. It's not worth trying to explain how to do it via email and if you don't have all the springs and contacts, it's junk. The switch is the same for all VT to VZ's, so a visit to the wrecker is probably the best bet.
    With regard to the seat back, it's knackered too. The upper end is retained by two large moulded hooks that are part of the seat back trim. They have obviously broken off and it wouldn't be worth trying to repair them as they probably would only break off again, and that's assuming that you can find the missing pieces sitting inside the bottom of the seat back.
    The bottom edge of that trim is retained by two plastic replaceable clips that can be removed without breaking, but it is fiddly. It requires a small screwdriver being inserted from below the trim up to the clip, and pusing the clip slightly upwards to disengage from the seat frame. These clips are brittle and will probably break. They cost about $3 each to replace. Again, the trim is a carry over from the VT, so the wreckers should be able to help again. I'm not sure, but the backs on the passengers front seat may be the same, so you might have a better chance of getting a good one that way. If the map pocket on your seat is good and the pocket on the replacement is stuffed, it's quite simple to remove the pockets and swap them over - two clips and four screws.
    Regarding the interior lamp, it has two earths, one via the switch and the other via the dome lamp. I'd say the earth wire between the dome lamp and light has become disconnected. There are two separate earth wires running from the lamp, so remove it and see if one has become disconnected. The next junction is at the foot of the centre pillar - if you removed the trim along the door sill when doing your sound system, you may have dislodged the connection.
    Good luck with all three items - let us know how you go.
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    thanks for the detailed reply mate.
    As for the switch, will be going to the wreckers as the rest of the parts for it are LONG gone. Just hope its not too hard to swap and solder the blue buld into the new one.
    I have the two large molded clips for the seat back. I was hoping to use some crazy kind of industrial araldite or something, just enough to hold them in there, its not like the panal would get much movement, if any.
    I may have very well bumped something in the lower-center piece, as i did fiddle with all the trims in this area when running the rear speaker wire through the stock door grommet. any specific thing i should look at down there? pics?
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Hi GTR
    I hope my attachment comes through for you. It's a copy of the wiring harness connections for the centre pillar. You probably need to check connections 1 and 2 for a guess - that should be the connection for the roof wiring with the main body harness.
    With regard to the seat back, it's probably been damaged by someone forcing a book or street directory into the pocket too hard and unless you can guarantee that nobody will do that again, it will be awkward to re-fit the seat back and feel comfortable that your adhesive will work. Still, if you can find the broken off bits, it's probably worth a go.
    Good luck.
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    R32 GTR 360AWHP
    Feb 2004
    Palmyra, WA
    Yeah dude, thems the ones. You CAN get it off without breaking them, but you'd have to work for holden or something and have been shown how to hehe. The clips are just a throwaway item pretty much
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    OK a bit of an update.
    problem 1, the window switch. Tried 2-3 wreckers and none had a single switch. The earliest model car they even had was the VT and none had electrics.
    problem 2, havent had time to look further into this, but will update when i finally have results.
    problem 3, found out what caused it. I have taken the whole back off the seat(broke 1 of the 2 clips down the bottom) and noticed how the mechanisms inside it work. More importantly, the one knob that stiffens/softens the center of the chair. Basically ive had it as far in(soft) as possible. And this means the band across the cushion and fully relaxed and my weight has been pushing the cushion in a fair bit, causing it to force on the rear panel. Then BAM over time that forcing has broken the top clips clean off.
    I hope that makes sense, its easier to show or speak, rather than type and still have it make sense.
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    No need for further elaboration, I get your drift. It's a bit surprising that the backrest cover can be broken by just sitting in the car with the lumbar support adjusted to the softest setting. I would have thought that there would be some clearance inside the seat but obviously not. New back cover or good s/hand one is the cure for sure, then adjust the lumbar support up a bit.
  15. #15
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    yeah the cushion seems to be quiet soft and pushes a fair way back. i can push on the front of the seat where you would sit, and it easily comes out the back to a point that would hit the back panel; with only one hand....
    also, i have managed to fix the clips, so will just have to adjust the lumber support to a point where this wont happen again.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. Mod Problems
    By VY 777 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-10-2008, 03:01 PM
  3. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  4. My VX has problems!!!
    By ls1berlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2006, 04:04 PM
  5. Problems
    By muffman001 in forum Car Audio
    Last Post: 18-05-2005, 10:59 AM
