Results 1 to 12 of 12
Thread: 2005 VZ 175 Flatspots
    VZ 2005 V6 175 Alloytec
    Mar 2006
    Newcastle NSW
    Unhappy 2005 VZ 175 Flatspots
    HI
    I am suffering Flatspots in my 2005 VZ 175 commodore (stock standard)
    most of times the car has no get up and go eg. if you put your foot down when approching a roundabout to beat the traffic it or at a intersection or pulling out into traffic there is just no power it seems to be stuck in top gear
    My exhaust is leaking around the flanges ( you can see the black) would this be a cause of my problem
    My airfilter is clean
    Also I am getting around 400KM out of a tank and i drive on the freeway alot
    Dont know what to do
    DRIVE IT LIKE YOU STOLE IT
    04 VZ Exec, HX Kingswood, VB Comm
    Aug 2008
    Sydney Easter Suburbs
    Mine is EXACTLY the same, round abouts are a total nightmare, it's as if you push your foot down and the car needs time to generate the power, for like 3 seconds or so. If i put it power shift it seems to help.
    Car: 04 vz exec.
    bludeck's Avatar
    bludeck is offline Wishlist = Blowa
    VZ Wagz
    Dec 2007
    Gold Coast
    try reseting the car, to do this disconnect the battery overnight. now when u reconnect the battery the car will 're-train' itself to your driving habbits. you may use a bit of fuel for the first week but it will sort itself out. 400km to a tank on the highway isnt normal. hope that helps
    VN Calais
    Feb 2006
    Thats shocking economy...
    My vz wagon gets way better and I'm in stop start traffic for most of my driving.
    -kRaZeD
    VZMAX is offline I THE GREAT
    vz svz
    Dec 2008
    my economy sits around the same but with mostly city driving...I had the same experience with the lack of power..as i too have a 175 kw in my svz...but ive put a catback exhaust and a cai pod setup which has improved things a lot...
    Ride: VZ SVZ
    MODS: Darkest legal window tint
    3 inch catback exhaust
    Genuine Holden front strut brace
    Xenon blue headlamps & number plate lights
    CAI with POD setup
    NEXT:
    upgrade music system
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    also check for voltage drop between the motor and battery on the earth side, heard of it before, this will cause high fuel consumption
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    squawk's Avatar
    squawk is offline squawk
    05 VZ Executive, A4
    Aug 2008
    Christchurch, NZ
    Quote Originally Posted by andyman View Post
    interesting i will have to check that on mine. is it normally loose terminals?
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    vz does have flat spots............ tis a mix of torque abuse control, having a 4 speed gearbox with a conservative diff........... oh and lets not forget it may be something else outside that.
    I'd go with new plugs, new fuel filter, injector cleaner and run 98 + pull your ecu fuse for a min and put it back in to cause the car to relearn from scratch. none of this battery disconnect overnight.
    otherwise.......... if it bugs you that much, either get it tuned or buy VCM Suite for example and tune it out.
    Maybe try a K&N Filter..... at minumum it'll add a bit more fuel as it allows more air, may help may not. Get some liquid gasket sealer and seal your exhaust as it'll effect your backpressure depending on how much it's leaking. alloytechs need back pressure for low down torque........ (not for the high end tho).
    *** On a side note, 2 hole mod.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    2005 VZ Commodore, 1993 VN Commodore
    Nov 2008
    Cabramatta
    have to agree with the k&n filter i put one in and you notice the difference, well worth it but the tune is the most effective, im getting my diff changed to the monaro style diff soon (3.46)
    VZ SILVER BULLIT
    Check out my sexy beast:
    http://forums.justcommodores.com.au/...5-vz-exec.html
    Mar 2006
    Newcastle NSW
    Took my car into Holden for a service and while it was there i got them to change the petrol filter as well Its come back alot better
    Im happy to drive it again
    vz x cop
    Feb 2006
    williamstown sa
    i had the same problem in my vz if u have a k&n air filter the oil from it ****s up the (maf) sensors. there is a maf clener made by crc coz u should clean it every 20000km as the same as the air filter.
  1. How do I remove flatspots in tyres?
    By Ozzie in forum General
    Last Post: 24-10-2008, 11:53 PM
  2. VR V8 Flatspots when cold
    By Paul Stratis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2007, 03:25 PM
  3. vs v6 flatspots when cold any ideas ?
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2006, 08:08 PM
  4. VR V8 Flatspots when cold
    Last Post: 08-04-2006, 10:18 AM
  5. Gen IV for 2005??
    By dsvtss in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-10-2004, 10:04 AM
