Results 1 to 15 of 15
Thread: thermo fan bypass switch?
    VZ
    Feb 2007
    Default thermo fan bypass switch?
    has anyone officially wired up a switch for thermo fans to be bypassed iv heard of earlier models being done but nothing as yet in the vz range?any help/diagrams would be great.also looking for the a/f or o2 sensor wire.thanks
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    it can be done just not the same way as doing older VT/vx with ecu wiring
    just need a relay and a switch and some time
    VZ
    Feb 2007
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    find the main feed to thermo fans under bonnet and trigger it with a relay
    then run wires into dash and place a switch somewhere
    most auto elects can do this for you
    or
    get ecu rewritten costly but good get tune at same time
    my ecu has been modded to turn fans on sooner but i also run a switch so can keep it very cool
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    ive read somewhere that you have to be carefull with the thermo fans comming on to early.
    The motor needs a cretain temp to be efficient and non wearing.
    Cold motors chew fuel
    Check out My SV8 One Tonner
    You can get a lot farther with a kind word and a gun than a kind word alone
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    i only put it on when in peak hr traffic or its really hot or making the car work hard
    but since Ive had ecu rewritten i don't use it much now days
    i also use the digital dash to see temp at all times and 88o is perfect temp to be at if on freeway with switch on it will go down bit to low into 70's bit to cold
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you got the 5.0L daron 88 is perfect on them.3.8 should be around 91 degrees to make sure all warmup settings are off
    VZ
    Feb 2007
    i just want it for when im stuck in traffic hate seeing the temp go up and down..any success in the vz range with a override switch yet?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    its not really getting much hotter it only goes up about 10-15 degrees before the fan kicks in just looks like lots on the guage
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    As long as its within operating temp I'm not sure what the problem is? As mentioned a cold engine can be a bad thing too.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    greengoose999's Avatar
    greengoose999 is offline vz SV6 ute
    Cammed M6 Ls1 Calais
    Dec 2006
    gee my sv6 ute normally sit between 90 and 95 but mostly low 90's. it used to be around mid to low 80's. i dont know why its running so hot lately
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    Dec 2006
  15. #15
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    mines pretty much the same - low 90's
    Even the track day in January, 38 odd degree day it only hovered around 100 when sitting idle, I think the second high powered fan only kicked in once or twice the whole day just after lunch and obviously track day = flogging the car
  1. How to fit thermo fan bypass switch
    By immortality in forum Holden Commodore How-To's
    Last Post: 18-04-2012, 06:06 PM
  2. How to bypass the hazard light switch (temp rewiring)?
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2011, 05:17 PM
  3. Netruel Bypass Switch
    By jwk87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2007, 11:19 PM
  4. Thermo Fan Switch
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2006, 01:09 PM
  5. thermo fan switch
    By cracker in forum Electrical Wiring / Questions
    Last Post: 19-08-2005, 10:32 PM
