Results 1 to 6 of 6
Thread: safe mode - reduced performance warning
    VZ SV6
    May 2009
    Question safe mode - reduced performance warning
    hi
    so i turn on my VZ SV6 2004 this morning, and bang! SAFE MODE alert, reduced performance alert came on.
    i was like ?????
    and traction control was off and wouldn't turn on etc..
    So i turned it off and back on and the error went away, drove all day, no issues whatsoever so I said fair enough.
    To be safe, I called the dealer and got it booked in for Wednesday.
    As i have heard stories about how dealers do 'services' and 'mechanical repairs' I wanted to make sure, so i dropped to the local Ultra Tune workshop and they plugged it into the diagnostics computer for $25.
    the following 4 errors came up:
    P2088 - intake camshaft POS control solenoid circuit low
    P0261 - cylinder 1 injection circuit low
    P0264 - cylinder 2 injection circuit low
    P0458 - Evaporative emissions control [can't understand my handwritting bit taken off] solenoid circuit low voltage.
    now, the problem is that, they cannot tell when this error codes came up because there is no date stamp (stupid thing, considering it is a LOG)
    So they cannot tell me if the errors are new or been in there prior to the car purchase.
    Anyways, it sounds to me like the battery is low, but it is reading near 14V, and i am told the solenoid typically dies around 130,000 km's, The car is on 126,000km.
    I asked the ultra tune tech not to reset them, that way Holden can see them etc..
    Ultra tune could not tell me what the problem was without looking into it further.
    The book says it is an issue with the throttle control system when the safe mode is on.
    I have 2 years free service and 3 years warranty with the car, so leaving it to Holden to do it.
    So, has anyone have an idea or has anyone had that happen to them?
    I checked other posts, no info there.
    p.s: apparently no more loan cars, while your car is getting checked/serviced. They have a rent-a-car service instead now. $25 for an astra up to $65 for a ute per day. I will ask more info when i go there and post it up.
    aka Lumina
    Jun 2009
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    DTC P0261, P0264
    ECM detects a short to ground fault in the control circuit of a fuel injector
    DTC P0458
    The ECM detects the voltage on the EVAP solenoid control circuit is less than 2.6 V when the solenoid is commanded
    off.
    DTC P2088
    The ECM detects a short to ground fault condition in a CMP solenoid control circuit
    Sounds like it could be a wiring fault somewhere. Have you done anything to the car which may have inadvertently damaged the engine wiring loom?
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    VZ SV6
    May 2009
    nope, none of the above
    I haven't even washed it since i bought it, or made anything to it since
    (have had the car for 2-3 weeks or so)
    thanks for the codes referral guide thing
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    could have stretched timing chains cos that sets off the camshaft sensor codes and reduced performance mode...
    late vz's and early VE's had the faulty chains that stretch
    VZ SV6
    May 2009
    I am not sure.
    I didn't check the VIN number etc..
    I have to drop it off in 8 hours, we'll see what happens
    i should really got to bed lol
    thanks for the help so far.
  1. Safe Mode?
    By 089JAY in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-02-2007, 07:52 PM
  2. has your VZ reduced in value
    By New2Holden in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-08-2006, 04:16 PM
  3. VH commodore-reduced price
    By 253PWR in forum Parts And Other Items For Sale
    Last Post: 21-12-2005, 11:11 PM
  4. ECU fail-safe mode?
    By mrhaboobi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-09-2005, 03:15 PM
  5. Fuel Consumption Normal Mode / Power mode (Overdrive)
    By peeete in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2004, 10:05 AM
Tags for this Thread
