Results 1 to 8 of 8
Thread: VZ Calais Firmware Version
    VZ Calais
    Jun 2009
    Default VZ Calais Firmware Version
    Hey All,
    Anyone with a VZ Calais, can you please check your firmware version and let me know what you have? I just want to check and see whether mine has been updated, as I took it to my local Holden Dealer to get done, and it came out with the same version I sent it in with. They are known to be dodgy. They wouldnt give me a straight answer whether it had been updated despite me asking 3 times.
    Does anyone know what the latest version is? Has anyone had theirs updated recently?
    Any info would be great!
    GTRwilson's Avatar
    GTRwilson is offline sell me your VY sigs!
    VZ SV6
    Nov 2008
    sorry cant help with your problem, but yes they like to duck and dodge a straight answer...
    VZ Calais MY06
    Nov 2006
    Canberra, ACT
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    if your going by the serial number in the dash cluster, that is the software version in the icu, that number has no bearing on the ecm/tcm/pim and bcm
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ Calais
    Jun 2009
    when holding mode and set while turning the ignition on you get a vers. no. then it displays a serial number too, then a gm part number.
    I was going by the version number. Is that meant to be the firmware version? one would think so..
    Can everyone check what theirs is and post it? mine was 000.041.080
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by nitrouz View Post
    as i said, that number only applies to the instrument cluster, has no bearing on the software version of the ecm/bcm etc etc,
    the software version is different to different types of clusters too
    VZ Calais
    Jun 2009
    ah ok. so I guess you can only check what vers it is by plugging it in and looking?
    How annoying, lol. how do i know they even did it?
    2011 voodoo thunder ss
    Jan 2009
    hi mate, mine says 000.038.000, so i would say it was updated, how much did it cost? i wouldnt mind updating mine, mine is also a vz calais
  1. My version of a brocky
    By RWRDME in forum VB - VC - VH - VK
    Last Post: 26-09-2008, 01:05 PM
  2. New PS3 Firmware released!
    By Trewman in forum The LAN Lounge
    Last Post: 10-07-2008, 11:28 AM
  3. Firmware Versions & Bugs
    By Lord-Data in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-02-2008, 10:52 PM
  4. My new Project (dan's version)
    By dan_man31 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-09-2006, 10:00 PM
  5. Ecu - Pcm Software Version
    By Phil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2003, 09:37 PM
Tags for this Thread
