Results 1 to 18 of 18
Thread: vz brake upgrades
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Default vz brake upgrades
    hey guys i got a quote for ve brake upgrades for my vz consisting of complete front upgrade to the VE spec 322mm slotted rotors, new calipers, new pads, new brake lines and fluid and i would just put slotted on the rear as 90% of braking is done on the front the rear is just to stablise the car, any way my question is
    is it illegal at all? as my insurer is fussy thats why i want to make sure!!
    thanxs for any input
    VZ SV6
    Aug 2008
    if i was you i got to the NVU website and check out there brake packages for the VZ. they got HBD and HSV. and youll find the rotors be slightly bigger in diameter. then you will have no hassle.
    link below
    NVU, Genuine Holden parts to suit Holden Commodore VR,VS,VT,VX,VY,VZ,Monaro,Statesman,Utes and HSV
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    guys i got some brakes that im gonna get what im asking is it illegal [ defect] for have bigger brakes
    GTRwilson's Avatar
    GTRwilson is offline sell me your VY sigs!
    VZ SV6
    Nov 2008
    i cant see why upgrading something to make the car more safe would be illegal?
    Just ring your insurer and ask if they will void your policy. Have you rung the RTA or who ever you guys use?
    Escape-The-Fate's Avatar
    Escape-The-Fate is offline HSV, i just want one
    VE SS, M6
    Nov 2008
    Gold Coast
    Quote Originally Posted by Archers View Post
    cant see it being a problem considering the VS boys are running VT front calipers and rotors?
    Sticking a Chev badge on any Commodore is like putting a Nissan badge on a VL
    EOI....VE SS 18" wheels x4 with 5000k's on new tread, 2 of have very minimal gutter rash (previous owner) otherwise like new send me a pm if interested.
    Vz ute
    Jun 2009
    Quote Originally Posted by GTRwilson View Post
    thats why race cars are low and have big wheels.
    but when u do it to ure car on the street its a no no.
    A vl i no got defected for a broken sunvisor clip????????
    So if they want to you can get for wateva they want.
    However i say do it
    VZ SV6 && 180sx
    Mar 2008
    Quote Originally Posted by baracuda View Post
    link below
    Has anyone had any experience with that HBD kit?
    VZ Skaife Senator & VY SS UTE
    Jun 2004
    Yes it's illegal any mod to the brke system has to be signed off by an engineer. fitting HSV brakes is probably going to slip through the cracks but your fitting newer VE style brakes which have a completely different hub setup to the vz this will require an engineer cert.
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by monaro327 View Post
    Correct. Atleast someone in this thread gave a factual and correct answer.
    Under SA Guidelines, any modification to the braking system needs an engineers certificate or to be apporoved by Transport SA.
    NIXONLS1 is offline Banned
    my mum
    May 2009
    Bansville
    Yeh it makes sence, but not always legal just like wider wheels give the car more grip, hence making it safer, but apparently its illegal.
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    thanxs monaro327 and dylan thats what i needed to know, so whats the best thing to do then? go hsv spec? or just slotted rotors neither of these will need an eng cert?
    1991_Vn2nV's Avatar
    Mar 2006
    Depends what you're after I guess. The HSV spec can be a bit expensive, and slotted rotors might not give you the desired gain.
    Its really only going to be an issue at Regency Park, normal Police will not pick you up for it and it is unlikely insurance will get picky enough to void anything because of it.
    You could pay $500ish to get them engineered though
    I have the same problem, as well as the fact that legal sized wheels don't fit over the brakes I have, so i'd have to get an engineers certificate for both the wheels and the brakes.
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Quote Originally Posted by 1991_Vn2nV View Post
    yeah man i think i will just go for slotted its about 300 ish for all 4 so that will be the way to go and the rest of the money will go to the 3.9s thanxs for the input mate, i look foward to seeing u sunday for cruise day m8
  15. #15
    Lumina SS (Commodore SS VZ 5.7)
    Sep 2008
    Default Try Wilwood
    Hi guys, just wanted to chime in, as I thought someone might find this useful. What I did was get a Wilwood kit. Comes with 330 mm slotted discs up front (drilled are like $20 more), along with 6 piston calipers, and 315 mm (I think on the back), also slotted with 4 piston calipers. You need to order the brake lines separate.
    Set me back around $3,500. Direct bolt on to a Chevy Lumina SS, which is basically a Commodore SS VZ or 2006 Pontiac GTO.
    Are they worth it? Well, yes, they are more responsive. Do not fade and make me feel safer when I push the car in rush.
    Another option would a StopTech front only kit. I think it comes with 6 piston calipers up front as well.
    In retrospect, I would do the StopTech kit. Its like around $2,000 without shipping and I think would do just as well. Why? Well, I checked my pads the other day after 6 months of daily bashing. The fronts have worn more than than the rear.
  16. #16
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Quote Originally Posted by ahmedibnaser View Post
    thats because u do 90 % of ur braking on the front m8 rear just stablise the car, thanxs for the input but thats alot more than i got qouted so im just doin 4 slotted rotors that will improve a lot more and for 340 for 4 i cant go wrong really,
    besides my insurence company wont cover me if i got to the ve spec [with is what i was gonna do 322mm]
  17. #17
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    hey archers, where abouts is this mob that you were getting the brakes off, im trying to source some brackets for them....ive seen them before, just carnt remember where, ive got some ve brakes lying around home
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  18. #18
    Jun 2004
    Archers, i hope you realise by slapping big brakes on the front and leaving the back brakes stock you'll mostly increase stopping distances in an emergency.
    Reason, ABS mate your fronts will lock up so easily compared to the back bringing the abs in much earlier. or so Harrop told me hence why they wont sell split kits of their monster line. a slight upgrade to the front is fine but 6 or 4 piston mono blocks and 350mm rotors with the stockers on the back will end up bad.
  1. vs brake upgrades
    By bazza24 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2008, 12:13 AM
  2. Brake upgrades??
    By jazzawithvg38 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2008, 07:46 PM
  3. Brake Upgrades
    By brownie82 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-04-2007, 12:01 AM
  4. Brake upgrades to the max.
    By digisol in forum The Pub
    Last Post: 11-01-2006, 04:34 PM
  5. Brake upgrades
    By kopper69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2005, 12:07 AM
