Results 1 to 16 of 16
Thread: VE SSV wheels
    Escape-The-Fate's Avatar
    Escape-The-Fate is offline HSV, i just want one
    VE SS, M6
    Nov 2008
    Gold Coast
    Default VE SSV wheels
    g'day all as far as i understand the ve ssv 19" wheels need the hub to be machined but also have read on here somewhere that the vz wheel nuts dont fit them properly or something, so my question is what would need to be done to get them to fit the vz properly?
    Sticking a Chev badge on any Commodore is like putting a Nissan badge on a VL
    EOI....VE SS 18" wheels x4 with 5000k's on new tread, 2 of have very minimal gutter rash (previous owner) otherwise like new send me a pm if interested.
    GTRwilson's Avatar
    GTRwilson is offline sell me your VY sigs!
    VZ SV6
    Nov 2008
    AFAIK just machined? Ive never heard of this problem with the wheel nuts.
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    VE SS, M6
    Nov 2008
    Gold Coast
    thanks troy, so in saying that, that would mean i need to get aftermarket wheel nuts that are specifed to the wider "cone" shape but fit the vz studs?
    Devils_Thunder's Avatar
    Devils_Thunder is offline Riding high...
    6.0L VZ SS Thunder
    Jan 2009
    Wodonga, NE Victoria
    What it's saying is that you need to fit the standard Holden wheel nuts to a genuine Holden wheel.
    When i had my VS i had a set of Holden wheel nuts for the for the VT Berlina wheels and another set for my 18inch xhp's.
    VE SS, M6
    Nov 2008
    Gold Coast
    its saying that the VE wheel nut "cone" bit which fits to the wheel is bigger..i have a set of mag nuts that fit my VZ, the question is will they be ok or does anyone know if there are mag nuts that have a wider cone at the bottom and fit the vz stud size? cus from wat i understand the stud size is also bigger on the ve?
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Escape-The-Fate View Post
    ve's use a 22mm nut, you will need genuine nuts of some sort as the tapered seat on the nut is different to aftermarket nuts, genuine is flatter, aftermarket is pointer
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    so would you need the VE nuts, or the VZ and lower nuts? or are they the exact same, and just all Holden nuts?
    VE SS, M6
    Nov 2008
    Gold Coast
    ahhh im comfused lol..all this talking about nuts haha..i got 20 mag nuts from bob jane, they fit my vr senator look alikes and the studs on the vz so will they be ok for the ve ssv's or i take a trip to holden and order some genuine holden vz "mag" nuts?
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    id use the original nuts that come with commodores, so probably the black long nuts that was used on the vy and vz tonners, crewmans and utes will suit you
    Exidor's Avatar
    May 2008
    Earth. For now....
    Some revision,
    VE nuts 22mm, studs 14mm.
    VZ and earlier nuts 19mm, studs 12mm.
    To safely fit VE wheels to VZ and earlier
    You will need 12 x 22mm nuts plus machining.
    The question is can you buy these 12 x 22mm wheel nuts?
    I'm not afraid.
    VE SS, M6
    Nov 2008
    Gold Coast
    thanks rodbol, pretty much wat i was asking...can u get 22x12 wheel nuts or if you went to an engineering shop of the sort would they be able to make 20 up?
    Exidor's Avatar
    May 2008
    Earth. For now....
    I'm sure some enterprising person must have
    realised the need for this size nut?
    Can you get them made? Probably, or try
    your local bolt supplier.
    I wonder if the people who sell and modify these
    wheels to suite earlier comm's sell the right nuts.
    I'm not afraid.
  15. #15
    VE SS, M6
    Nov 2008
    Gold Coast
    yeh might try the NUT & BOLT shop soon considering its just down the road and see what they have to say about it
  16. #16
    VH + VK Gas Cars
    May 2004
    Not really VZ related, but talking about retro fitting VE rims.
    I want to fit some VE 16x7 Machined Steel Rims to my VK. I have been told to get some original VE nuts but reading through this they wont fit (14mm instead of 12mm) on VK studs. Another idea I was told is to fit VZ mag wheel nuts but I don't think the chamfer will be correct for the VE rim.
  1. new wheels to replace 15"steel wheels
    By peewee in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-04-2009, 04:00 PM
  2. [VIC] Want to swap SS VE wheels for CalaisV Wheels
    By bigfut in forum Swap / Wanted to Buy / Trade
    Last Post: 17-02-2009, 06:23 PM
  3. different width wheels and flat bottom steering wheels?
    By Troy711 in forum VE Holden Commodore (2006 - ?)
    Last Post: 24-09-2006, 05:50 PM
  4. WTB: VZ calais wheels or other genuen holden wheels
    By commy92 in forum Swap / Wanted to Buy / Trade
    Last Post: 29-06-2006, 06:08 PM
  5. VZ Calais wheels wanted - VY Berlina wheels for sale
    By I just want one in forum Swap / Wanted to Buy / Trade
    Last Post: 19-08-2005, 08:21 PM
