So i;m trying to install Blue LEDS in my VZ MY06.
The lights above the rear licence plate work, the lights above the rear door work, but i cannot get the light above my head to work. I have tried two different brands of the 4LED lights to no avail. The LED fits perfectly but does not switch on.
Anybody else have trouble with this? Should i try a different type of led?
http://forums.justcommodores.com.au/...ml#post1185792
Go to this thread from StealthCalais. He has just completed the conversion and listed the LED globe types on post #56 of his thread.
LED's only work when put in one way. have you turned the globe itself around?
CruznCalais
[GAMBLR]
The VZ is here! About time!
quick question, are white LEDS above your number plate illegal in Victoria?
should work if u plug it str8 in r u sure the globe isnt blown
tried 2 different sets of globes now.. no good
i went down to autobarn and i spotted a Monza LED kit (6 led strip with converters for pretty much any connection)
so i bought the last blue one they had, installed it in the left map light and hurrah! much brighter than a single led would be!
unfortunately they only had one so still waiting for it to come in stock =\
from what i've heard it's only illegal if you cannot read the rear license plate. so leds should be fine.. (just what i've heard and most likely wrong)
