Results 1 to 3 of 3
Thread: where is the fuel pump?
    VZ Executive
    Nov 2008
    Default where is the fuel pump?
    hi quick question
    where is the fuel pump in a VZ alloytec sedan?
    if it is in the fuel tank can it be accessed without taking the tank out? if so how/where?
    cheers
    EDIT: ok have found out it is in the fuel tank, is there an easy way to test if it is working without pulling the tank out?
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Quote Originally Posted by 2LOUD2OLD View Post
    hi quick question
    cheers
    Are you having fuel supply problems - why do you need to check the fuel pump?
    If it is playing up, a lesson I learnt from an NRMA tech who came to get my VR going years ago was to belt the bottom of the fuel tank with a lump of timber. It shocks the pump into working but is only a stop gap. Once the pump starts to play up, it should be replaced. According to the manual, fuel pump replacement required tank removal but if it's anything like the VR, it can be removed without disturbing the tank.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    tank out, pretty easy to get out, just try and run it low on fuel first, as it can get a bit fumbly by youself
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  1. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  2. Will a fuel pump pump oil?
    By VYMAD in forum General
    Last Post: 12-11-2008, 09:07 AM
  3. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  4. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
