Results 1 to 15 of 15
Thread: Power Control Module stuffed?
    Phantom WL Caprice 5.7 V8
    Feb 2009
    Default Power Control Module stuffed?
    Well I just got a call from the dealer as to why my car (WL Caprice)is playing up (some gauges not working (fuel and temp), power button and parking sensors also not working) and he tells me one of the computers has lunched itself...
    He says it's the power control module or PCM? Is this powercontrol module the same as the body control module?
    Nice and expensive to replace of course ($1700 for GM and $1100 for aftermarket).
    Is this the going rate or is there another avenue I should know about for fixing this issue. Is there somewhere in Perth I should be going to if it can be fixed, or is it simply a matter of getting it replaced (and reprogrammed apparently)??
    Looking for advice!!
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    power train control module, id get a second opinion first, go see a reputable auto-electrical shop first
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Feb 2009
    Yeah I think you're right. I just talked to a couple of people (a gen3 tuner over here in WA aswell as AMCAP/Holden parts distributor) and they reckon it sounds more like the BCM is stuffed. And by the way, AMCAP tells me the price quoted by the dealer for the PCM is a lot more than what they have them listed at.
    Something fishy going on me thinks. Hopefully I'll get to the bottom of it soon..
    Feb 2009
    While I'm at it, can any WA members suggest a good auto electrician in Perth I can take it to to check these issues out?
    Feb 2009
    Well just an update..
    Friday night I was changing my rotors and discs on the Caprice and remembered what another forum member had said about his car playing up in a similar way and it turned out to be a knackered negative terminal on the battery.
    So I undid my negative terminal and gave it a jiggle left and right, tightened it up again and then turned the car on.
    Would you believe - all my problems were gone! Fuel gauge/DTE and temp gauge were back, as were my power button and parking sensors!!!! So two days later and so far so good - like nothing was ever wrong!
    Darn fool eejit dealer - just about had me for a PCM when it looks like I probably never needed one! even tried to tell me my parking sensors weren't working because one is slightly damaged on the outside, which caused them to all not work. The one had been damaged since I bought the car but all the rest still beeped and worked, but he wouldn't listen that the parking sensors had stopped working at EXACTLY the same time as the other 3 things...
    So, I know that everyone here knows to stay away from dealers but this is just another story to add to the growing list of dealer incompetence...
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the poor terminal will give very similar symptos to a faulty PIM, Powertrain Interface Module.
    the PCM has nothing to do with the park sensors etc.
    glad you sorted it.
    Rob
    Feb 2009
    INteresting about the PIM Doctor Bob as a few people have also mentioned that module. What symptons are common to a 'faulty PIM'??
    vz ssz ute
    Jun 2009
    Blackcaprice, just had the pim replaced in my ssz ute. when this goes, nothing goes. call a tow truck. cost me $500. $100 for the part and $400 for the labor. mechanic mate of mine told me it would have taken them 1hour at the most.
    BullittSV6's Avatar
    BullittSV6 is offline Donating Member
    2005 VZ Commodore SV6
    May 2008
    Adelaide, South Australia
    Quote Originally Posted by BlackCaprice View Post
    I said this last year and I'll say it again, find a dealer who treats who well and stick with them. Some are questionable but some will have staff that know what they are doing. Dealers, particularly in rural areas where dealers aren't as common as metro areas, think they hold the monopoly but the truth is that there is another dealer, whether that be in the next suburb or next town who will gladly take your business.
    Feb 2009
    Thanks for the info fellas.. Even though the problem seems to have gone as quick as it came, I'm half expecting it to come back so I'm on alert!
    wetwork65's Avatar
    wetwork65 is offline A wet business
    VY Berlina V8 & VZ Adventra LX8
    Mar 2006
    With the goblins in South West WA
    Feb 2009
    wetwork65's Avatar
    Mar 2006
    VZ SV6
    Aug 2008
    i try and avoid mine here on the coast.(name start with something squatters live in along the coastline)was going to see what the one in Mandurah is like
  15. #15
    wetwork65's Avatar
    Mar 2006
    Won't mention their service level - (I have been warned by the moderator regarding my comments on another dealer's sales techniques).
    Suffice to say I have chosen to go to Harvey Holden, which fortunately is close to my workplace. They are good and fairly priced.
LinkBacks (?)
  1. 19-07-2009, 07:21 PM
  1. what does the BCM (Body control module) do???
    By muggo05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2009, 01:24 PM
  2. FS [VIC]: power arial module and centrol locking module
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 24-09-2008, 06:41 PM
  3. body control module
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2008, 08:52 PM
  4. WTB: Stuffed VN-VS V8 Ignition Module.
    By PREDATR in forum Swap / Wanted to Buy / Trade
    Last Post: 20-02-2008, 01:49 PM
  5. Power Windows stuffed
    By VSSPak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2007, 10:47 PM
