Results 1 to 10 of 10
Thread: Incar L.e.ds
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Default Need help installing L.e.ds(neons)
    Bought some Leds from Jaycar, got them fitted in the front, working fine, was wondering if anyone has installed them in the rear footwells (under the seats) and where abouts they put them..
    please if u have photo's too would be good..
    Life starts at 200km/h
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    Hey mate, as for my car, i bought 2x packets of twin neons, and i cut off the cig plug in piece and wired it into the cig power source and attatched a switch in the pos side of the wire to be able to have on or off w/e i want and ran both packets off the same point (cig power) and just glued the rear ones under the back seats and ran the wiring under the centre consol, hope that can help out a bit mate.
    Social.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    where did you earth it in the rear, i found that the metal under the seats actually earth it,
    FAT.36L's Avatar
    FAT.36L is offline 8,000RPM FTW!!!
    Turbo S13 Onevia
    Sep 2008
    Maitland
    I think phreddy is doing front and back footwells now check out his chapter
    social's Avatar
    Nov 2008
    South Aus
    well as i said i snipped of the cig plug for each set of neons and intertwined both pos wires together and both neg wires together and then just spliced into the cig lighter and taped it up (like professionally btw) and the earth was the cig lighter for both so yea..
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    yeah i have got them all wired together, but it turns out i must have a bad earth as they all went dull.. shit happens i will look at them again tommorow..
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    Hey guys soz to dig up a thread.. Pretty newbie with this stuff, Whats the go with 'splicing', is that just wiring half the wire to the neons, and half the wire to the ciggie? Also looking at replacing the boot light with a neon, would that just simply be a case of unclip the bootlight and extend pos and neg to the neons?
    Thanks guys,
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    use a 3 way switch so you can select white or neon light... if you going to join two wires, get the connectors from Supercheap and use a soldering iron and the heat shrink tubing..
    if you are a not really electrically/mechanically minded i would get someone to help you whilst your doing it.. BUT i tapped into the glove box light, heard of people tapping into the fuse box and other areas that have been powered.
    Make sure you use a switch when you do it and try and connect to the accessories power so if you leave the lights on by accident they will cut out when the power does
    hope it works out for you
  1. [VIC] Nesa 3.6" incar dvd player single din
    By mad_vx_5spd in forum Parts And Other Items For Sale
    Last Post: 21-09-2007, 04:05 PM
