Results 1 to 25 of 25
Thread: Does wheel size effect speed??
    sincy is offline Donating Member
    VY
    May 2009
    ACT
    Default Does wheel size effect speed??
    got a VZ ute with the 15" chasers.. just bought some 19 wheels.. will there be a big difference, if any in the speed/acceleration/anything else i should know about.. and is there a way to fix it??
    cheers
    VT spac super6
    Nov 2008
    Riverton sa
    roller diameter is not much different.. speed will be slightly out most likely
    can be recalibrated to suit by holden
    VY
    May 2009
    ACT
    Quote Originally Posted by HARVZ-6 View Post
    thanks.. will the speed be higher or lower???
    MUT4NT's Avatar
    MUT4NT is offline RatRod Gem Wagon?
    WH international// Gemini Wagon
    Aug 2008
    PERTH
    its either way usually
    Quote Originally Posted by walesy View Post
    how dare you compare a commonwhore to a stato/caprice we have way more class!
    Quote Originally Posted by GEN3RATD View Post
    bags are fail, just go and buy a boat.
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    If the tyres are of a larger diameter than stock your speedo will show
    a lower reading than true. eg 10% larger diameter tyres =10% lower KPH approx.
    Also larger diameter tyres will be like lowering (taller) your diff ratio.
    ie your rpm will now drop at a given speed.
    I'm not afraid.
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    VZ S Ute
    Jul 2008
    go to holdens and get it recalibrated
    if u go bigger ur speedo will show a lower speed that what you are doing
    dont ask me the margain etc
    Travy's Avatar
    Travy is offline A bogan with style
    Hilux 4x4 Xtra Cab
    Feb 2008
    All depends on overall diameter not just wheel size.
    The tyre size calculator listed above tells you exactly the percentage its out by.
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    i dont believe holden can recalibrate it .... not if it has more than 12 kilometres on it. i may be wrong though.
    SIR LS1
    the two ton go kart
    ducker85's Avatar
    ducker85 is offline Calais man
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    WRONG
    the rim size wont affect your speedo until you get 20's or larger, as long as you run the correct tyre profile, the 19's are actually 100% perfect for yuor over all diameter were the 18's are 2mm smaller affecting the speed the slightest
    i know anything that come factory on 15's in the ex models can run 19's fine, the VE changed there tyre profile and you can get 22's on them before affecting the speedo
    to go further if you fir the incorrect tyre profile to your stock factory wheel this will f*ck up your speedo more then the 19's will
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by TUF UTE View Post
    thats only the kilomteres they can't adjust.
    they'll be able to correct the speedo cos its just a tweak of the software.
    Chev badges are an instant fail
    ducker85's Avatar
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    Quote Originally Posted by ashbox View Post
    but there no needs to if you go 15's to 19's the speed DOESN"T change at all, not 1km, nothing.
    trust me I've spend many hours in my wheel shop asking questions and i've run these wheels and double checked with the GPS speedo
    JBDrifter's Avatar
    JBDrifter is offline Now in a Calais
    VZ Calais & VT Exec Wagon
    Oct 2006
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    as for acceleration you may find your car slightly slower, as bigger wheels usually mean more weight (of course depending on wheels its quite a broad statement) and 10kgs weight difference can end up being quite a difference. I had 18's on my VP and it goes a lot (can actually feel the difference) better with 15's on I think they were about 10kgs difference per wheel. theres some sort of calculator on the net that can tell you how much 10kgs is when its rotating or somewhat.
    as for the speedo, it'll be out by bugger all but you can get speedo pulse changers or something that you can change the pulse outputted by the gearbox going to the speedo.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
  15. #15
    2005 VZ SV6, with 19' VY Maloo Mags
    Feb 2005
    Melbourne, Vic
    I have a sv6 std rims were 17" have now got 18"s and the speedo is 2k out. eg i go 70 by speedo the actual speed is 68. as test through the check you speed things they have on the freeway's
  16. #16
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    mine vs ute came stock with 16's ive now got 18s with low profiles does that mean my speedo could be slightly out?
  17. #17
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by harvs01 View Post
    it prob was out by 2kms with 17's too.
  18. #18
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by WogBoyz View Post
    ever so slightly prob un-noticable.
  19. #19
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Quote Originally Posted by ScoHar View Post
    with the walkinshaw clubby its 3 seconds quicker around a track with 20's over the standard 22'' rims
    The Black Beauty
  20. #20
    VZ SV6
    Jan 2009
    ive got 19's on my SV6 n my speedo hasnt changed, i checked it against my sat nav
  21. #21
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Quote Originally Posted by TVR-161 View Post
    Yep... can't get good tracking with 22's... nor 20's.
    If they didn't have the massive brakes on the clubby and put 18's, it would have been even quicker.
    Getting bigger wheels on a car will not affect the speedo reading by much so long as you put tyres of a legal diameter on, so max 15mm diameter increase.
    Good luck with the wheels.
  22. #22
    woody13666 is offline Dan05sv666
    05 vz sv6
    Jul 2009
    hunter valley
    the main thing that generally will be effected is your acceleration usually increase of tyre size gives slower acceleration and a higher speed then is indicated on your speedo,having 19-20's might put your speedo out slightly by 1-3km's but at a higher speed of 100km etc
  23. #23
    ducker85's Avatar
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    All cars are out anyway from factory they have a 4% allowence or something my Dad's BRAND NEW STOCK AS A ROCK VE SSV is 4km out at 114 he's doing 110 is car is 100% box stock and has less then 30,00kms
    wheels 15 to 19 DONT NOT AFFECT YOUR SPEEDO
  24. #24
    GMHCalais is offline [TUKN20Z]
    VY SII 5.7 Calais, VS SS SII HSV Enhanced
    Jul 2009
    adelaide yo
    Quote Originally Posted by ducker85 View Post
    if everyone is so worried. theres also other ways to measure if your out.
    hence your trip computer that can show the speed your doing electronically.
    i did it with mine and it said i was doing 60, but the electric speedo said i was doing 58 so its hard to say? ive only got 17's on the calais must i add..
    Slammed 5.7 VY calais II tuckin G8 20'z
  25. #25
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Trip computer is only as accurate as it's calibration - it'll need recalibration if you put a different diameter wheel/tyre on. Same goes for the dial.
    If you want an accurate speed use a GPS.
  1. Wheel size on vy ute?? how big can i go????
    By hbdvysute in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-10-2009, 08:36 PM
  2. VE Wheel Size? (Same as any other car?)
    By ascottaudio in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-05-2009, 01:48 PM
  3. Best Wheel Size
    By INDACLUB in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-12-2008, 07:56 PM
  4. What size wheel will fit?
    By ducatis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-08-2006, 06:15 PM
  5. Wheel Size Please
    By holden69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2005, 11:16 PM
