Results 1 to 4 of 4
Thread: how to fit 20s lowered with no scrub?
    Turismo SV6
    Mar 2006
    Default how to fit 20s lowered with no scrub?
    For all you boys and girls running 20" rims lowered ride hieght and the such what have you done to make them fit? I have pedders superlows all round, gaurds rolled and 225/35/20 tyres that scrub like buggery on the rear with even the slightest unjulation in the road surface. Im pretty sure its at the bit on the rear bumper but not 100%. Cheers
    VY SS UTE
    Jun 2009
    Mandurah, WA
    Note: I will not be held accountable for any injuries and/ or damage to your car as it is your decision and you will be the one held responsible as these are only sugestions.
    hey,
    ah ha, i think i see your problem, i have 20inch incubus paranormals which have a rediculously huge offset and lowered on SL's which means the wheels scrub like buggery. all i did was attack the rear bumper (plastic bit) where it joins the metal guard with an angle grinder, a dremel, severely roll the guards and it only scraped on the odd occasion when there was a fully load or a really big bump. next i got it lowered on SSL's and i ended up getting the part that attaches to the hub on the car machined down about 3mm and it very rarely scrubs at all.
    i would recommened guard rolling, then modifying(cutting) the rear bumper/ guard, then if only your last resort get the rims machined and only a little bit like 1-3mm at the most, but this is illegal and highly unrecommended and could be unsafe and dangerous.
    cheers,
    George
    Travy's Avatar
    Travy is offline A bogan with style
    Hilux 4x4 Xtra Cab
    Feb 2008
    Id say your offset isnt ideal.
    I have 20 x 8's 245's guards not rolled, tapped up a little in one small section and I only get very very minor scrapping with people in the back on large bumps
    VY SS UTE
    Jun 2009
    Mandurah, WA
    sorry to hi-jack this thread,
    yeh my offset is rediculous it's like 20p which with 8.5inch rims on 225/35r20 leaves about 5mm when parked but it looks wicked from behind cos the wheels stick out the sides alittle at the bottom and makes it look hell low and wide.
    and yeh strike check your wheel offset and make sure it's as close to manufactures specs as possible, i think holden late models are about 48p
    cheers
  1. Anybody lowered their VE themselves???
    By muzzz89 in forum VE Holden Commodore (2006 - ?)
    Last Post: 04-11-2009, 08:51 PM
  2. vp live axle tyre scrub
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2009, 12:22 PM
  3. VR, VS ute does yours scrub?
    By mws in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2008, 06:56 AM
  4. lowered car
    By vpallme in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 12:45 PM
  5. Another Will They Scrub Thread...
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2006, 04:29 PM
