Results 1 to 12 of 12
Thread: PS pump diagram
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Exclamation PS pump diagram
    Peoples,
    Anybody have an exploded diagram of a VZ
    Alloytec power steering pump?
    Rebuid time!
    Rod.
    I'm not afraid.
    vz berlina v6
    Aug 2007
    Exidor's Avatar
    May 2008
    Earth. For now....
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Hey Rodbol
    What is wrong with your power steering? Is it frothing the oil and groaning heavily like my son's Acclaim?
    Exidor's Avatar
    May 2008
    Earth. For now....
    Quote Originally Posted by Calaber View Post
    Hey Rodbol
    As mentioed in a previous post,
    No frothing or strange noises.
    Just strange steering feedback along with pronounced
    bump steer.
    It's now a process of elimination to determine
    what is the cause. Starting with the pump.
    Rod.
    I'm not afraid.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by rodbol View Post
    bump steer.
    Rod.
    bump steer is mainly caused from larger wheels and different suspension setup, p/s dosnt really play much role in it, wider wheels and low air pressure will make the steering more vague.......
    if the steer pump is on its way out id be looking for, shuddering, frothing, leaking and noisy
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Exidor's Avatar
    May 2008
    Earth. For now....
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Candyman?
    Are you the artist formerly known as Andyman?
    lol yeah, thats hakhawk for ya
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    I remember the previous post. I'm with Candyman - if you don't have any of the typical P/S symptoms, it isn't likely to be the source of your steering probs.
    Exidor's Avatar
    May 2008
    Earth. For now....
    Had the car at Pedders today.
    They do recognize there is a steering issue.
    However they don't know what it is.
    They suggest it might be my suspension setup.
    You can't expect much for $14 I suppose!
    I'm not afraid.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    ok what, rim size, tyre profile and suspension and tyre pressure are you running?
    Exidor's Avatar
    May 2008
    Earth. For now....
    (C)Andyman,
    King springs FE2 height,
    Monroe GT Sport gas shocks,
    17x8 VZ SV6 wheels with Falken
    ZE329 235/45 tyres @ 31psi.
    Not dramatically modified.
    Until recently had OEM 15in wheels on. Still had the
    same problems although the bigger wheel and tyre combo
    does increase the steering issues.
    Pedders claim the shocks on the front are too stiff.
    However this problem predates the modified suspension.
    The mods have just made my issues worse.
    I'm not afraid.
  1. Vs water pump - Electric pump.
    By Lazin in forum V6 Development And Modification
    Last Post: 06-05-2011, 07:08 PM
  2. fan belt without p/s pump and air con pump
    By stubang in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-01-2009, 09:21 PM
  3. Will a fuel pump pump oil?
    By VYMAD in forum General
    Last Post: 12-11-2008, 09:07 AM
  4. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  5. Does anyone have Fuel pump wiring diagram
    By iroczinoz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2007, 01:02 PM
