Results 1 to 6 of 6
Thread: "Check Powertrain" Message
    VS, VZ
    Dec 2008
    Default "Check Powertrain" Message
    Hi
    Had my battery replaced today - VZ Berlina wagon, V6.
    After I collected the car and started it, I noticed that the clock was wrong but the radio pre-sets were all OK. Reset the clock.
    Next time I started the car it came up with a "Check Powertrain" message.
    What should I do? Is it a consequence of the battery being replaced or might it be a genuine message?
    Look forward to assistance.
    Regards
    Acrow
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    May have logged a fault code some how. You may need to take it to a place that can scan the car and see what the code is.
    My VZ did this when the oil pressure switch cacked it.
    and 3 Dangerous non ABS VN's
    VS, VZ
    Dec 2008
    Quote Originally Posted by 88GreenVN View Post
    Can I reset it myself and see if it recurs?
    Regards
    Acrow
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Acrow View Post
    Regards
    Acrow
    Some you can - like the service reminders, but if it pops up again - it's scan tool time
    VZ acclaim wagon 04 3.6L
    Sep 2009
    disconnect the neg battery terminal for a few minutes. That resets the ecu.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Quote Originally Posted by dave1979m View Post
    Might work but it has already had the battery disconnected when it was replaced.
    Have a look at post #2 with instruction on how to reset the computer.
LinkBacks (?)
  1. 06-07-2009, 10:54 AM
  1. "Check Powertrain "
    By vz2822 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-02-2011, 07:16 PM
  2. Check Powertrain warning message
    By Luke0011 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-03-2009, 01:41 AM
  3. "Check Oil" Alert Message
    By VicCop in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-11-2007, 10:20 PM
  4. Should I wait for "systemcheck ok" message to start the car?
    By vinni30 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-01-2007, 02:35 PM
  5. Is the warning "service engine oil" the same as "check oil" ?
    By morris in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-12-2006, 04:36 PM
