Results 1 to 8 of 8
Thread: Vz ute pre out
    Vy Sv8
    Jun 2009
    Default Vz ute pre out
    Hey guys didnt know weather to post here or in audio seeing it about vz's i posted here.
    Am chasing info on how to connect preouts into a stock vz ss ute?????
    Cheers guys
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Vy Sv8
    Jun 2009
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by vs-ute-119 View Post
    Wow that looks hard maybe a job for a audio shop...
    phreddy has a fella in w.a doing the mod install, wrx884 is his name i think
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Vy Sv8
    Jun 2009
    Yer the guys at Alberts car audio told my mate to chop the end of the rca cables and connect them to the speaker output wires coming out of the wiring harness, we got the subs working but its hell shit like one of the speakers stops working and yer sounds shit...
    They also said this is the easyiest way cos you dont need pre outs....
    Cheers guys
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Cheers guys
    lol thats asking for trouble, you need something with a 5v output, that wont cut it, and as you said sounds like shit,
    id also suspect that would be a better idea if you were using high level inputs, i.e using the speaker wires straight into the amp in the high input......
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Using the high level (speaker) outputs from the headunit means you get some distortion introduced by the headunit's relatively crappy internal amplifier. Phreddy's mod gets the output from before the amplifier stage, so you get a clean signal.
    If you are using high level outputs you should connect them to the high level inputs of your amp if it has them, or use a high to low level converter. Connecting the RCA leads directly to the high level outputs is a bad idea because the amplifier is designed to drive a 4ohm speaker, and the amp isn't a 4 ohm load.
    Input impedance - Wikipedia, the free encyclopedia
    If you chose to use high level, then you can get your headunit programmed to run 4 channels like in the sedan/wagon and use the rear channels to run your amp and the front channels to run your door speakers
    Vy Sv8
    Jun 2009
    Quote Originally Posted by TMM View Post
    We tried the rear speaker wires and it didnt work but now i know...
    Mate went to the audio shop today and they set it up the exact same way we were throught the speaker wire and it works like a charm just played with the amp settings and used different wires.
    I told my mate that I can get hold of phreddy and get shit done but he wanted it done straight away haha.
