Results 1 to 21 of 21
Thread: Keeping the car in PWR Mode
    04 VZ Exec, HX Kingswood, VB Comm
    Aug 2008
    Sydney Easter Suburbs
    Default Keeping the car in PWR Mode
    Hey all,
    Does it damage the car over an extended period of time to keep the car in Power Mode?
    I normally keep it always in Power Mode as the car is just slow and unresponsive to drive without.
    Thanks
    Devils_Thunder's Avatar
    Devils_Thunder is offline Riding high...
    6.0L VZ SS Thunder
    Jan 2009
    Wodonga, NE Victoria
    shouldn't do any long term damage.
    All the power button does is hold gears longer before shifting, you will propably use more fuel though.
    VZ SV6 05
    Sep 2008
    Exactly, all it does it just rev out the gear more than what it would normally do, which means higher revs, using more fuel, and therefore somewhat wearing the car out quicker, but it wont "damage" anything as such i would imagine, your just using more revs.
    Aug 2008
    thanks for that,
    but i know this is strange but i actually get better fuel economy when i've got power on, then again i don't usually rev it up to high, so i guess it's also down to driving style as well.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    i would also suspect it wouldn't do any damage either, your probably getting better fuel economy cuz your not working so hard with the car with the PWR mode on..
    Life starts at 200km/h
    Junny's Avatar
    Junny is offline purrrrrr
    VUII Maloo + shitty painted vp
    Hangman Champion!
    Jan 2009
    what about if you had a shift kit?
    Hit the star under this post if it was any help to you =D
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    It won't do any damage to have the PWR button on all the time. But I have to ask, if you are not revving the car much or driving it hard, then why would you even want to have the PWR button on? And obviously you wouldn't get better fuel economy under the exact driving conditions due to the engine revs being kept lower in normal mode. So I would say that you may have driven slightly different and more sedate hoping to get better economy with PWR on. But once again I ask, why would you even want the PWR on all the time if you drive normally?????????
    When people say you might get better economy because you aren't working the engine as hard because its revving a little more, well this isn't true. If you are gentle on the throttle and not putting load on the car, the most economical way to drive is to change gears as early as possible without labouring the engine. And no, I don't mean changing at 1100rpm. In most cars whether auto or manual, if the next gear is selected earlier and you are driving under normal throttle, then the car should see better economy.
    The only reason I can see why you would want the PWR button on is that if you were driving consistently hard, and wanting the gears to hold slightly longer, or mainly for towing. When towing, and due to the engine having a load behind it, holding gear slightly longer is then beneficial and reduces the chance of labouring the engine.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    VZMAX is offline I THE GREAT
    vz svz
    Dec 2008
    Quote Originally Posted by HoldenOnn View Post
    HOLDENONN...SPOT ONN..perfect explanation...
    Ride: VZ SVZ
    MODS: Darkest legal window tint
    3 inch catback exhaust
    Genuine Holden front strut brace
    Xenon blue headlamps & number plate lights
    CAI with POD setup
    NEXT:
    upgrade music system
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    The only time i use PWR mode in normal driving is when im about to overtake as it kicks down to 1st gear instead of second gear at low speeds.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Also PWR prevents you from shifting into 4th gear afaik, so it's a good idea to keep PWR off if you're just cruising on the freeway .
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by TMM View Post
    Are you sure about that? I reckon my VY shifts into fourth over 80-90 kph.
    Mar 2009
    The car will still shift into 4th/5th (depends on what gearbox) when in power mode, it will just hold 3rd/4th for longer.
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    I don't believe this to be the case. But if it was the case, then why would you leave PWR on just so you don't get into top gear?? Modern late model cars computers are very smart and it knows when cruising on a freeway that selecting top gear is the best thing to do. As long as the car isn't under load ie going up hills, towing etc, then there is no reason why freeway speeds shouldn't be conducive to using top gear.
    Ofcourse different cars are a different story. For example, my VL Turbo stays in 3rd gear until atleast doing approx 85km/h due to me having an increased stall converter in the car, and in my VLT, fuel economy is not an issue that concerns me, but labouring the car under stall speeds certainly does concern me.
  15. #15
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by VYMAD View Post
    Hmm interesting. In eco mode around 80-85km/h mine goes into 4th. In pwr mode it's in 3rd up to at least 100km/h even when just cruising along - it goes up to 4th straight away if i press the button.
    I haven't tried it over 100km/h with pwr on yet.
  16. #16
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Either way, there is no need to leave it in "PWR!!!" mode. Your gearbox is gonna have a hard time as well as the engine.
  17. #17
    svsex is offline big blue
    190 sv6
    Jun 2008
    the power mode doesnt just let the motor revs higher it also lets the geerbox behave diferently such as keeping the revs up wen ur heavy right foot is lifted of the pedal wen cornering and so on. well thats wat mine does in my 5 speed auto. might be difertn in the 4 speeds
  18. #18
    Escape-The-Fate's Avatar
    Escape-The-Fate is offline HSV, i just want one
    VE SS, M6
    Nov 2008
    Gold Coast
    keep mine in PWR..just feels a bit more touchy and i live ontop of a hill..so wen going up that it drops back a gear sooner and doesnt labour the engine as much..freeway hits the start of ramp in 2nd click third about 2500/3000 rpm and once im up to 100 back off the accelerator and it drops into 4th..cruising along if i need to overtake and put the boot in a lil..drops back to 3rd instead of thinking about it and off i go. I also thought about the fuel consumption and it hasnt changed for me..only way it will is if u think its a v8 supercar because ur in power mode..and it stretches the gears to like 5000rpm all the time..
    Sticking a Chev badge on any Commodore is like putting a Nissan badge on a VL
    EOI....VE SS 18" wheels x4 with 5000k's on new tread, 2 of have very minimal gutter rash (previous owner) otherwise like new send me a pm if interested.
  19. #19
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    FYI, there are different line pressure maps for eco/pwr modes. in PWR mode, with increased line pressure, the box will change faster/hold better. simply put, a quicker gear change means less slippage which means less wear on the band/clutch packs etc.
    please ignore, this applies to ecotec. however one would imagine that it's the same for alloytec
    Body by Holden, Soul by Brock
    the Legend will live forever
  20. #20
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    Quote Originally Posted by svsex View Post
    You are correct for the 5sp Autos in the SV6 which you own and my Calais which I own. But this is not the case for the original thread starter named mainpath. He owns an executive and they had the 4sp auto which isn't adaptive to your particular driving style like the 5sp auto is. They are totally different behaving boxes.
    As for the revs being kept up, well this is true. But it actually senses far you had pedal pressed, then senses how quickly you lift, and if the parameters are correct according to preset values in the computer , then once your foot is lifted off the pedal, the auto will hold that gear. Its effectively apapting to different driving styles which is something the 4sp could not do.
  21. #21
    vz calais 190KW A5 CHE TUNED
    Feb 2009
    SmithField NSW
    very True!! the 4 speeds dun do this as my mum v6 wagon doesnt hold the gear once u take ur foot off the pedal. very neat thing the pwr mode in the 5 speed autos!
  1. Keeping it LHD!
    By 08_adaml in forum The Pub
    Last Post: 24-04-2007, 08:47 AM
  2. Keeping busy
    By Pretender in forum Jokes/Humour
    Last Post: 08-05-2006, 05:05 PM
  3. Vn 5Lt Diagnostic Mode How To Put The ECU Into This Mode
    By scotty1000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2005, 06:12 PM
  4. Fuel Consumption Normal Mode / Power mode (Overdrive)
    By peeete in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2004, 10:05 AM
