Results 1 to 23 of 23
Thread: serious fuel problem
    VZ acclaim
    Jul 2009
    Default serious fuel problem
    hey guy's I've just bought a VZ acclaim done 57k's on it. I've got weird problems
    1) when fill up not getting maximum km's getting around 400km sometimes lower
    2) randomly smell fuel
    3) when ignition is on fuel gauge drop's about 1/8 of tank while idling
    4) filling up constantly
    5) also while driving gettin around 13-18lt's which isn't right
    somebody help me please......
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    so i guess you have checked for fuel leaks?
    has you car got the fuel guage calibration fix?
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ S Ute
    Mar 2009
    Sydney, NSW
    Both 1 and 5 are the same for me, might be the way we drive. And 4 is kind of a consequence of that way
    MY WHITE VZ S UTE
    TWO HOLE MOD AND EXHAUST DONE
    LOWERING, TINTING AND SOUND SYSTEM STILL TO COME
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Quote Originally Posted by JT Ute View Post
    I'm not afraid.
    VZ acclaim
    Jul 2009
    nah no fuel leak its getting a diagnostic check at holden see if it will pick up any defects costing $130 though
    Tuttle's Avatar
    Tuttle is offline stupidity reigns supreme!
    VZ Acclaim
    Feb 2009
    i got an acclaim about a year ago with same amount of Km's and i have all of those problems except i can still get about 11L/100km.
    the "km's to go' is WRONG, it is very rarely right on mine so i just drive with the knowledge of how big the tank is.
    i did read somewhere on here that when installing the VZ float they get bent which causes the computer to show wrong readings. not sure if this is a common thing
    let me know what holden say cause i would be interested in fixing mine,
    VZ lumina Executive
    Jan 2009
    qld
    It usually happens when you leave the fuel cover loose. I happened with me . I always tighten up the lid and all smell gone.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    tuttle, sounds like it needs the fuel guage re-flash
    VZ SV6
    Aug 2008
    have u checked the fuel cap? is it loose after you filled it up?hence the fuel smell. i had a simular problem and while it was still under warranty holden reckons i had a faulty filler neck and replaced the whole tank.
    but still check the cap especialy after fueling up as it works loose coz the tank has been presurised. new cap fixed the prob
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    always tighten the fuel cap and even so that wouldnt cause such a loss of fuel.
    do i have to take it to holdens to get the gauge flashed?
    VZMAX is offline I THE GREAT
    vz svz
    Dec 2008
    my fuel economy sits around the 14-15 lts mark no matter what I do or how I drive I can't get it down..I always use 98 octane and have cai and catback exhaust fitted...my car has only done 23000k's...
    Ride: VZ SVZ
    MODS: Darkest legal window tint
    3 inch catback exhaust
    Genuine Holden front strut brace
    Xenon blue headlamps & number plate lights
    CAI with POD setup
    NEXT:
    upgrade music system
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Tuttle View Post
    yes, get them to check whether its had the re-flash first though
    VZ S Ute
    Jul 2008
    my ute fuel gauge says its empty after about 400-430km
    i can get a maximum of 45-50L in the tank then.
    ive read somewhere there are some problems with the VZ
    just fill it up when it says to fill up
    think about it... a full tank is only 45L instead of 75
    vs wags
    Jan 2009
    i had the same problem with my vp man, 15.2L/100km with a soft foot. there had been a lot of talk about oxygen sensors improving fuel economy quite a bit. i got one on the weekend and chucked it in, its a fairly straightforward job too.. basically disconnect the battery and out with the old on with the new(with a vp that is.. not sure about the newer motors). ive only done about 30kms since so im still waiting for an accurate reading but i recommend you look into maybe replacing yours too
    adam
    Quote Originally Posted by Burns48_VR View Post
    Hey guys i was painting a set of interceptors and i got some of the silver paint on the wheel, just wondering if anyone knew of a good way to get it off or to cover it up??
    Quote Originally Posted by jamaar4 View Post
    Learn some can control toy
  15. #15
    VZ SV6
    Aug 2008
    you be suprised how much fuel you can "vent-off"
  16. #16
    Tuttle's Avatar
    VZ Acclaim
    Feb 2009
    Quote Originally Posted by baracuda View Post
    20L in two weeks.....unlikely
  17. #17
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    VZ fuel tanks (and most likely others) always maintain at least 10 litres of (unuseable) fuel to maintain pumps and pressure in system.
  18. #18
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    maybe change fuel filter n spark plugs........ just an idea of the top of my head. otherwise yeah check for leaks......... run 1 ltr of metho thru a full tank of fuel....... help clean it out a bit.
    PS. If the cars tuned at all....... that'll suck fuel if it's been tuned incorrectly.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
  19. #19
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by bigdaddycool View Post
    haha i can vouvh for that,
    dont turn off dfco and dont enable 100% max ve flow across the range, its very touchy and responds well, but sucks fuel haha
  20. #20
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
  21. #21
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Danoz View Post
    How are you going with your tune Andyman? Got it all running well yet?
    ah yeah, its going haha, slowly, get it on a dyno soon
  22. #22
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
  23. #23
    Sep 2008
    with ur fuel smell is it only when you first start the car maybe? .......... there's two times u may smell fuel.......... when it's warming the cats (cold start) or if your constantly in Catalyst Overtemp....... as the car will overfuel to keep the exhausts cool....... Maybe you have something stuck in your catalyst converter or it's getting old.......... just another idea for you.
  1. fuel problem
    By prjacksonau in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-05-2009, 01:29 AM
  2. fuel problem
    By reggie_c2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2008, 05:44 AM
  3. fuel problem
    By 308commodore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2007, 02:35 PM
  4. VN fuel problem
    By R Photon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2006, 01:16 AM
  5. VS fuel problem
    By drums1974 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2005, 05:10 PM
