Results 1 to 12 of 12
Thread: how to stop window rattle??
    Escape-The-Fate's Avatar
    Escape-The-Fate is offline HSV, i just want one
    VE SS, M6
    Nov 2008
    Gold Coast
    Default how to stop window rattle??
    g'day got window rattle in my vz...wanna know how to fix it??
    Sticking a Chev badge on any Commodore is like putting a Nissan badge on a VL
    EOI....VE SS 18" wheels x4 with 5000k's on new tread, 2 of have very minimal gutter rash (previous owner) otherwise like new send me a pm if interested.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Chances are the window runners have gone hard or the door is out of alignment. Which windows are rattling?
    Visit my Facebook page
    VE SS, M6
    Nov 2008
    Gold Coast
    2 front ones..mainly drivers
    vz exec
    Aug 2009
    my driver's side window is rattling too...
    at least it sounds like the window, the rattle is coming from the front door keyhole area (lower right corner of drivers side window)...
    the door may be slightly out of alignment (sagged) as when i close the door i can feel it liftin a bit when the hook hits the latch... what effect does this have on window rattle?...
    so does the door need to be adjusted before fixing the rattle? or are they two seperate issues....
    thanking you in advance.....
    VZ Excutive Wgn ex Police
    Aug 2009
    I have the same problem but can get rid of it some times by opening and closing it again. How to fix
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    ive had this issue recently, noticeable when driving over bumps... and would shit me to tears.. could also elbow the inner door panel and get the rattle sound
    found it to be the electric window assembly that is pop rivited into the door had come loose...
    so i drilled out the pop rivets and bolted the assembly into place...
    6mm diameter bolts, with flat washers and nyloc nuts
    its perfect now
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by Not_An_Abba_Fan View Post
    I agree, the little plastic window runners might need to be changed . one if mine didi it due to the plastic breaking and causing the metal lug that holds the runner on to rattle against the window .
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by auke View Post
    Our VZ is the same - quick flick of the window down and up normally fixes it.
    and 3 Dangerous non ABS VN's
    VE CLUBSPORT M6 6.0L
    Dec 2009
    i have the same problem in my vz sv6, i got 2 12' subs and it makes the the 2 front windows rattle really bad even when i got them off it still does it.. but nothing else does rattles desides that..
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    Quote Originally Posted by impulsesv6 View Post
    its perfect now
    take the door trim off, and operate the window up and down
    and watch the window assembly and the pop rivits... its only slight but enough...
    swear by it
    123oriordan is offline Red Spark
    vz executive wagon
    Apr 2008
    do you have a 123 abc step by step method of solving this annoying rattle. it would be much appricated.
    vz executive wagon
    Apr 2008
    THe rattle was getting worse, patients thin,radio louder.
    So today undid the door trim, and inner plastic. Watched window go up and down a thosand times, Door open and closed a thosand times. Sat inside,stood out side and then did the following.
    Packed all runner which seem to be in good condition with greese.
    Then did as ImpulsesV6 said drilled out the 2 centre pop rivets for the motor.
    Only one at a time then installed 1/4" bolt , spring washers x2 to be sure and a lock nut.
    Then did the top one of the two , a bit tight to get into it but used the large front hole to get my arm in there and use the spanner all tightened up all back together close door open door close door open close perfect.
  1. How can i stop/help my boot rattle? VT
    By Yokomitsu in forum Car Audio
    Last Post: 16-06-2009, 03:41 PM
  2. Stop a VN Air Vent Rattle
    By 88GreenVN in forum Holden Commodore How-To's
    Last Post: 09-08-2008, 08:44 PM
  3. Window wipers won't stop
    By VR_Senator in forum Electrical Wiring / Questions
    Last Post: 10-03-2007, 07:43 PM
  4. How to Stop Window Rattles VY
    By New Supercharger in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-01-2007, 04:45 PM
