Results 1 to 10 of 10
Thread: vz rooflining
    vz ss and vs statesman
    Mar 2009
    Default vz rooflining
    hey i was just wondering if any one has the same problem i have a vz ss sedan and i just noticed that the roof lining in it has sagged in the middle does anyone have the same problem or know how to fix it without having to buy a new one? thanks
    bludeck's Avatar
    bludeck is offline Wishlist = Blowa
    VZ Wagz
    Dec 2007
    Gold Coast
    sagging is usaully the glue letting go, it can be fixed by re-glueing it back. good quality spray adhesive, bonding preferabbly. can do it yourself if you think u can get the lineing out. otherwise there are companys around that do these repairs
    GTRwilson's Avatar
    GTRwilson is offline sell me your VY sigs!
    VZ SV6
    Nov 2008
    I have a similar problem, i even made a thread about it on here:
    Mystery hood lining problem
    I never figured out how to remove the hood lining so if you ever get it, let me know so i can attempt it.
    Mar 2009
    hey didnt realise there was already a thread any way mine looks like that but not as bad just a slight crease in the middle. its not the material falling away from the back of it. its the whole thing sagging rite in the middle. mite have to get a new one if it gets any worse. thanks for your help
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    when you press the bulging piece of the head lining, does it feel soft and light like a suspended piece of material, or can you feel the backing behind it, say 4mm max?
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Mar 2009
    i can feel the backing behind it its hard to push well kinda its definetly not just the material
    GTRwilson's Avatar
    VZ SV6
    Nov 2008
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    ill get back to you guys, generally its just remove all the trim around the roof, lower the headlining then bend it in half and squeeze it through the rear door
    Mar 2009
    VZ SV6 && 180sx
    Mar 2008
    My mum had hers replaced recently. Local trimming joint charges $300, and they did a great job.
  1. vq rooflining into vn exct (will it fit)
    By flyen in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2006, 06:37 PM
  2. Rooflining and RWC
    By crazyspoon05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2006, 10:41 PM
