Page 1 of 3 123 LastLast
Results 1 to 25 of 65
Thread: RPM drops while accelerating in SV6? [video]
    VZ SENATOR
    Mar 2009
    Arrow RPM drops while accelerating in SV6? [video]
    Hi Guys,
    Not sure if any of you could help me, but I've noticed my rpm fluctuate when im accelerating through second gear. It drops off slightly for a few seconds then picks up where it left off...
    In the video I'm applying even acceleration through second gear... anywho take a look at the video below and let me know what you think:
    YouTube -Uneven acceleration in SV6
    2011 voodoo thunder ss
    Jan 2009
    yeh mine does the same mate, there was a post on here a while ago, same thing, but only on the 5 speed box, seems to be something to do with torque management and the 5 speed box :S
    squawk's Avatar
    squawk is offline squawk
    05 VZ Executive, A4
    Aug 2008
    Christchurch, NZ
    VZ SENATOR
    Mar 2009
    VZ SV6
    Aug 2008
    got it with mine too and i got a SV6 with 5 speed auto. auto scheduled to get fliud replaced in 15,000km time. but i replaced the whole accelerator assembly with a HBD alloy pedal version and the problem has virtually gone away.see with it being fly by wire the sensor is a variable resistor and like any variable resistor if left on the same spot to long it will leave a carbon/burn deposit and that will cause the flucuation.
    VZ SV6 && 180sx
    Mar 2008
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    I posted with this exact same problem a few months ago!!! I took it to holden and they told me i needed a new gearbox lol. I told them to get stuffed. I think it a electronic throttle control problem. Just give it a little more gas and it wont do it.
    Mar 2009
    Quote Originally Posted by baracuda View Post
    Where did you get your pedals, im VERY interested.
    VZ SENATOR
    Mar 2009
    hi torana355,
    I remember you posting that thread and was following it closely, but thought it might have been a slightly different problem to the one I was having!
    baracuda let us know about those pedals! were they hard to insall?
    anyone else come up with a different solution to this problem?
    Mar 2009
    Quote Originally Posted by mattsv6 View Post
    hi torana355,
    Yeah that is the exact same problem. I should have posted a video when i put up my thread lol. Its kind of good to hear as it points more to the drive by wire then the expensive gearbox.
    VZ SV6
    Aug 2008
    the pedal i got from NVU.(click on link below)
    NVU, Genuine Holden parts to suit Holden Commodore VR,VS,VT,VX,VY,VZ,Monaro,Statesman,Utes and HSV
    the other pedals (brake and clutch,footrest) i got from AMCAP (those who are in WA) otherwise Holden be the go.
    the accelerator pedal was not to hard to swap it just undo the top 2 bolts and it will slide out from the bottom retainer slide(ensure u slide it upwards) then remove the plug.take note plug got a clip on it u got to push in.now the bolt top left(brake side) is easy 10mm socket on small ratchet.but the other one you got to "feel your way" i ended up using a small 10mm ring spanner to undo it.like you got heaps of room but it all sits behind the BCM and fuse panel and didnt feel like ripping that out.
    all up the whole job took a hour
    cost under $200
    and no need to convert a V8 pedal for V6
    Mar 2009
    cost under $200
    Legend!!! Woot woot
    VZ SV6 && 180sx
    Mar 2008
    VZ SENATOR
    Mar 2009
    Thanks for the write up mate, much appreciated! I'm sure NVU will have at least 3 emails about this in the morning
    Just one question though, when you say the problem has virtually gone away - does it still happen slightly at all? Did you find it made any other impact?
    VZ SV6
    Aug 2008
    i think the new pedal has got a slightly stiffer spring and seeing the pedal is straight rather then curved on top, compared to the V6 one. i have noticed i rev slightly higher and quicker (due to diffrent foot position on pedal)and no longer hit that spot.even when i try to accelrate real slow i cant seem to re-occur the problem= fixxed to me.
    the alloytech 190 has got variable air intake where it switches between cruise and power.
    that would be me next port of call if it re-occured.coud have dirt build up?just coz u got an airfilter dont mean it traps all the dust.
    any other impact?....yes!!! it improves the look in the footwell heaps and car looks more sportier and me mates love it
    VZ SENATOR
    Mar 2009
    sounds good mate, thanks again Im sure a few of us will invest in those pedals
  17. #17
    VZ SV6
    Jul 2009
    hey mate i had the same problem with my sv6, when accelerating under load the car starts missing. or when crusing then trying to speed up this happens. the car starts missing lightly. Do this and let me know if the car starts missfiring. Put the car in D (drive) pull the hand break up, press on the breaks hard and the press on the accelerator to reach 5000 RPM. If the car starts missfiring the problem is from one of your coil packs. try this and let me know of the out come send me a private message or some thing, then i'll let you know how to find out wich coil pack it is.
  18. #18
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
  19. #19
    VZ SV6
    Aug 2008
    never heard of this method unless i wanna blow sumfin up.....
    Quote Originally Posted by please_mail_2me View Post
  20. #20
    VZ SV6
    Jul 2009
    VZ SENATOR
    Mar 2009
    Hey mate, No offence but I dont really wanna do that to my car, sounds like it could fcuk up something!
  22. #22
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    why wouldnt you just drive it to 5000 rpm... or as a proper workshop would do... stick in on the dyno..
  23. #23
    VZ SV6
    Aug 2008
    exactly!!!!
    Quote Originally Posted by impulsesv6 View Post
  24. #24
    VZ SV6
    Jul 2009
    the foreman of holden did this while i was watchin and the problem was one of the coil packs was faulty, replaced right there and then and the problem gone,
  25. #25
    VZ SENATOR
    Mar 2009
    I've had a car that was misfiring before, and the problem doesn't really feel like that. Revs fine through all other gears under all other loads... so I don't think thats the problem unfortunatley.
    Just out of interest, how much did a new coil pack set you back?
    Cheers.
  1. vp 5.0lt speedo drops
    By hoon1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2007, 11:02 PM
  2. drops out of 5th
    By Uber_Matt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2007, 12:06 AM
  3. Replies: 2
    Last Post: 15-09-2007, 10:30 PM
  4. VN drops back a gear when speedo drops out
    By V8commodore_chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-11-2006, 12:18 AM
