hi i have a 2004 SV6, i have noticed a rattle noise from the back of the car. it sounds like a bell. well i then jacked the car up to see where it was coming from, i found out that it is the shock absorbers. the outer skin of the shock absorbers is loose and it keeps wabbelling around and coming in contact with the second half, (the thinner part) of the shock absorbers. dose any one know of a fix for this
Also how many K's are on the car?
The shocks are working fine and not leaking, i dont really see a need to replace them. just a rattel noise when drive on the speed hump
i dont know there must be a fix to it some how. just to stop the rattle maybe put hard grease around it that might work
The shield is spot welded to the shaft at the top. The weld has broken and now the shield rattles.
How many k's has the car done? Over 40 000 and they are basically stuffed anyway. You may think they are OK, but when replaced it will drive like a new car.
Mine are making a noise as well they need to be replaced.
VZ Executive Wagon 2006 Hot Red, 18" Genuine Holden Rims, Window Tint, Kenwood MP3 Deck, Satin Chrome Highlights, Chrome Exterior Highlights. My Ride Link
VR Executive Sedan 1993, White, 15" Aftermarket SS Rims, Sony MP3 Deck. (Currently Being Restored) My Ride Link
Yep thats a sure sign they are rooted, no fix just replace, it's not expensive.
