Results 1 to 11 of 11
Thread: noisy interior blower fan
    vz exec
    Aug 2009
    Default noisy interior blower fan
    hi all
    my 2006 vz exec has a noisy interior blower fan, all the way from speed 1 to 4 (even with AC on or off)... its sounds like i got a leaf or stick stuck in there, or worse...
    can someone please tell me how to get to the fan and pull it out in order to check (chuck?) it out... (or please redirect me to a relevant thread)
    thanking you in advance.....
    cheers
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    1. Unclip the plastic cover under the passengers side footwell.
    2. You should now be able to see the base of the fan. It's clipped in on the left hand side and also held in with three screws. Undo the screws, unclip the cables the entire fan should slide right out.
    3. If you shine a torch up in the space you should see a plastic grill covered in dust and maybe some leaves, might be worthwhile removing any of these if you can... back to the fan...
    4. Undo the screws at the base of the fan and unclip the cables, you should now be able to slide off the plastic cover.
    5. In my case the entire thing was covered in a sh!tload of black dust and crap which had got into the bearings and was causing the noise. I cleaned the whole thing up with some contact cleaner and a wet rag before relubing it with some spray grease.
    6. After cleaning, simply reverse the steps to refit and connect all cables. Fan should now be whisper quiet
    Thank "MatsV6" for the above.
    I'm not afraid.
    VZ SENATOR
    Mar 2009
    Thanks for pasting the above. If you want a little more detail about the problem check out this thread:
    VZ Calais Climate Control Fan Noise
    A mate of mine used that technique but unfortunatley it didn't fix the problem for him. Have a go yourself and if it doesn't work you can always replace the fan... although I'm not sure how much a new one would cost??
    vz exec
    Aug 2009
    thanks rodbol and mattsv6...
    i got the fan out but it looked relatively clean (no leaves)...
    should i have been able to crack into the black housing to get to the bearing?? i didnt want to force any plastic bits apart so i sprayed silicon lube throught the gap between the blades and the black housing hoping to hit the spindle/bearing.... i got the fan back in (the hardest part of the job) and it was definitely quieter (not as bad as the youtube clip)...
    thanks again for the quick help.....
    VZ SENATOR
    Mar 2009
    Guys, I just posted this in the other thread but in case you're wondering...
    I just called up Coventry's here in WA, a new fan is only $50 so if the problem doesn't go away at least it's a cheap fix
    VZ SENATOR
    Mar 2009
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    I've a VZ exec and also have a noisy fan, it’s not a ticking but a deeper sounding vibration as if the fan was warped or unbalanced, gets louder as you increase fan speed (could possibly be something soft flapping about).
    So happy after reading those instructions I’ll have a go at getting in there, I thought the entire dash may need to come apart! If I can't see any foreign matter I’ll replace the fan with a new one.
    Cheers!
    02 VT commodore
    Nov 2006
    Perth, West Aussie
    $50.00 where is that price from ? I live in Perth and the best price I could get any where is $195.00
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    Quote Originally Posted by VN_Bucket View Post
    I bought mine from Amcap in Welshpool. They basically have the same prices as Conventrys (possibly cheaper)but have EVERYTHING in stock and i recommend going there, they're a massive logistics company.
    $50 is correct, what has more than likely happened VN_Bucket is you've asked for a blower fan or just "fan" and they've quoted you on one of the radiator fans, that's what happened to me.
    You gotta say NO, THE FAN INSIDE THE CAR THAT IS USED BY THE AIR CON. Until you get a price close to $50 they're still telling you the wrong one.
    I said "blower fan", "interior fan" and they still kept quoting me the damn radiator fan.
    Sorry I don't have the part number handy here at work, but just be persistant until they look up the right part for you.
    VZ
    Jun 2010
    Quote Originally Posted by Exidor View Post
    I've just had a look at my fan due to very similar noises from it. I would like to ask what is the recommended lubricant to use on the fan? I believe WD40 or similar is no good.
    Thanks.
    VR 3.8 EXECUTIVE
    May 2006
    Three years passed but this threads really helps. Thanks guys, I fixed my problem like a breeze
  1. noisy fan vr v6
    By slick1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2009, 03:36 PM
  2. Noisy 3.8
    By Loupy31 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-04-2008, 12:39 PM
  3. Vt Interior fan blower
    By dutransport in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-04-2008, 09:16 PM
  4. Interior blower fan dissapears when accelerating
    By rowdybloke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2008, 08:16 PM
  5. Noisy Air Con
    By Zedlen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2005, 01:56 AM
