Results 1 to 19 of 19
Thread: New Xtreme Clutch problem?
    ROLNBG is offline Banned
    vz sv6 M6
    Jan 2009
    Camdan
    Default New Xtreme Clutch problem?
    Hey, Just installed The xtreme solid flywheel, kit to my ride, as the old one was RS, however now it is rattly at idle, which goes once you put your foot on the clutch. The main problem though is that in 2nd and 3rd on acceleration there is a shit lound growl/rattle coming from the box, now im aware that replacing the duel mass f/w with a solid one is going to cause these issues, but this bad?? Can some one tell me if this is normal for this conversion?? i also changed the CSC, and the oil with perite SIN 75w90 oil, is this the correct oil for the Asin 6speed? could i dampen it a bit by putting a heavier grade of oil?? anyway id like some advise??, Cheers
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    by replacing with a SMFW you have removed a damper thus the rattling, depending on the qaulity of the install is is worse, mine makes hardly any sound and i have the same clutch.. so i guess it may be slightly noisy.. it is normal
    Life starts at 200km/h
    VZ Skaife Senator & VY SS UTE
    Jun 2004
    rattle at idle is normal, as for in gear under acceleration noise, mine made some in gear noise but it went away after the first half an hour of driving that part doesn't sound normal to me. as i said mine had a bit of noise in each gear but after i put about 50k's on the clutch that disappeared and never returned. mine rattles at idle but is really no loud then stock once in guaged.
    vz sv6 M6
    Jan 2009
    Camdan
    I't only does it at in the rev range of 1000rpm to 2000rpm under load in 2nd gear and up...Could it be the oil, what does holden recommend for the 6 speed?
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    the oil you used is fine.......
    give the clutch a couple hunded km's first and see how you go
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Jun 2004
    vz sv6 M6
    Jan 2009
    Camdan
    Quote Originally Posted by impulsive View Post
    just curious, who installed it?
    my older brother who is a diesel machanic, he's built his race mini, works at jim reads work shop building top fuel motors. And he rebuilds all the navy boat motors. and my dad helped a little bit who has been a diesel machanic 30 years..
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by monaro327 View Post
    every holden dealer i've called recommend ATF for the sv6 6spd
    aisin spec is 75w-90 though, so yes it is fine,
    dexron111 may allow it to shift better, but it wont protect the gearbox aswell as the 75w-90, ive only every heard holden recommend dex111 in the tremec boxes aswell
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by ROLNBG View Post
    How noisy is it?
    What???
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by PaulSV6 View Post
    How noisy is it?
    What???
    paul a dmf, generally dampens driveline shock/vibration,
    replacing it with a smf, 'can' induce a chatter in the gearbox, thats the name of the game, from what ive been told, more common in the xtreme clutch
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Oh ok, thanx Andrew.
    When i heard him say that the rattle is normal in a gearbox, i couldn't stop laughing.
    Ill guess ill find out when i get an aftermarket clutch.
    The Blue One
    Quoted for truth
    vz sv6 M6
    Jan 2009
    Camdan
    [QUOTE=PaulSV6;1244772]How noisy is it?
    It's pritty bad when it under load in 2nd and 3rd at about 1300rpm till 2000rpm then goes away. the gearbox shifts fine and fells fine. Well i took it 4 a cruz yesterday and it seem it doesn't do it when the gearbox oil is still cold but when it gets to running temp it comes and goes at times.
    Jun 2004
    Quote Originally Posted by andyman View Post
    wouldn't a gear oil allow faster shifting then ATF? ATF to my understanding has alot of friction modifier so the sycros would take longer to come up to speed. but having all the friction modifiers plus the fact ATF can handle alot higher temps should result in alot less wear.
  15. #15
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    but dex111 is roughly 10w-20 grade oil and is more on the hydraulic oil side of things, gear oil being thicker, is more clingy and generally dosnt run back as quick, keeping bearings that are splash lubed, lubed longer then thinner oil, the thinner the easier it is for it to squeeze out of componenets, eg, synco etc etc, as such, makes gear shifting easier, syncros brake the surface of the oil quicker, make contact and brake quicker, but at a cost of not protecting the internals as well, but, thats what ive been told by mentors of mine, guys with the expierance, ive learnt from....
    really i go by whats recommended unless a dealership can give me a document showing a superceded spec, ill go by the manufactores spec in the book, eg, the tremec box is rated for atf, some rodeo gearboxes are recommended for regular engine oil etc, etc,
    monaro, not doubting what the dealer has said to you, but i wouldnt be surprised if the dealers you rang think the v6-v8 boxes are the same, too many times ive talked to someone at a counter or ill informed worker and they've given the wrong spec or information
  16. #16
    Jun 2004
    Chill mate, i had no intension of using the atf in my gearbag. the advice i got from redline was to use an 75w-90 GL4 oil they said dispite the manufacture recommending a GL5 oil they get the best results with a GL4 in the sv6 6spd. they reckon the GL4 oil allows for faster shifting then a GL5 oil.
    Mainlube recommended an 75w-90GL5 oil as per spec.stating there GL5 oil will shift just as fast.
    Mobil/castrol/penrite/nulon all said i can only use holden's oil in this box which is bs as holden don't make oil so they are buying it some where.
    holden dealers say just use atf.
  17. #17
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    haha, i wasnt even getting worked up lol, i thought you were using atf though, anyway rule of thumb is if it gets hard a shifting you could go higher visco engine oil, if that dosnt free up so good, then go to atf
  18. #18
    Jun 2004
  19. #19
    Jun 2004
    Mate you didn't meantion that you got the button clutch version of the xtreme, button clutchs are normally quite noisy. from my understanding they quieten up when you give them a bit of a thrash so try that. don't go over board just try and get a bit of heat into it.
  1. Clutch Problem
    By Andre's SS in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-10-2008, 07:58 PM
  2. vs ute possible clutch problem?
    By Conn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-08-2008, 02:54 PM
  3. Clutch problem??
    By AngryVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-09-2007, 06:11 PM
  4. Xtreme Korruption Driving Team
    By Holden V8 SS Ute in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-05-2007, 12:32 AM
  5. Clutch Problem
    By Andre's SS in forum General
    Last Post: 30-06-2006, 02:48 PM
